Mr. Coffee DW13 Base Removal
    1. Mr. Coffee DW13 Base Removal, Base: step 1, image 1 of 2 Mr. Coffee DW13 Base Removal, Base: step 1, image 2 of 2
      • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
      • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
      Ask FixBot
    2. Mr. Coffee DW13 Base Removal: step 2, image 1 of 2 Mr. Coffee DW13 Base Removal: step 2, image 2 of 2
      • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
      Ask FixBot
    3. Mr. Coffee DW13 Base Removal: step 3, image 1 of 1
      • Gently lift the base cover to expose the inside of the coffee machine.
      Ask FixBot
Tess Bradley
388 Reputation
3 Guides authored
Cal Poly, Team 10-31, Maness Winter 2014 Member of Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 32
All Time: 3,979
