Mr. Coffee DRX5 Water Reservoir Replacement
  1. Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: step 1, image 1 of 3 Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: step 1, image 2 of 3 Mr. Coffee DRX5 Water Reservoir Replacement, Water Reservoir: step 1, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
    Ask FixBot
  2. Mr. Coffee DRX5 Water Reservoir Replacement: step 2, image 1 of 3 Mr. Coffee DRX5 Water Reservoir Replacement: step 2, image 2 of 3 Mr. Coffee DRX5 Water Reservoir Replacement: step 2, image 3 of 3
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
    Ask FixBot
  3. Mr. Coffee DRX5 Water Reservoir Replacement: step 3, image 1 of 2 Mr. Coffee DRX5 Water Reservoir Replacement: step 3, image 2 of 2
    • Remove 2 hose clamps from heating element. Remove heating element from tubes.
    Ask FixBot
  4. Mr. Coffee DRX5 Water Reservoir Replacement: step 4, image 1 of 3 Mr. Coffee DRX5 Water Reservoir Replacement: step 4, image 2 of 3 Mr. Coffee DRX5 Water Reservoir Replacement: step 4, image 3 of 3
    • Using a Phillips #1 screwdriver, remove one 10mm screw, and three 11mm screws connecting the reservoir to the base and remove reservoir from the base.
    Ask FixBot
Michael Chhim
205 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 22
All Time: 822
