Mr. Coffee DRX5 Warming Plate Replacement
  1. Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: step 1, image 1 of 3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: step 1, image 2 of 3 Mr. Coffee DRX5 Warming Plate Replacement, Warming Plate: step 1, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
    Ask FixBot
  2. Mr. Coffee DRX5 Warming Plate Replacement: step 2, image 1 of 1
    • Slide display out of the way.
    Ask FixBot
  3. Mr. Coffee DRX5 Warming Plate Replacement: step 3, image 1 of 3 Mr. Coffee DRX5 Warming Plate Replacement: step 3, image 2 of 3 Mr. Coffee DRX5 Warming Plate Replacement: step 3, image 3 of 3
    • Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
    Ask FixBot
  4. Mr. Coffee DRX5 Warming Plate Replacement: step 4, image 1 of 1
    • Pull heating element out of the way.
    Ask FixBot
  5. Mr. Coffee DRX5 Warming Plate Replacement: step 5, image 1 of 1
    • Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
    Ask FixBot
Michael Chhim
205 Reputation
2 Guides authored
1 Guide Comment
Interesting that you can take the thing apart, do nothing else but put it back together again, and it’s supposed to be fixed? What about the step of replacing the broken part? I don’t see mention of that.
destravlr - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 925
