Mpow MPBH063 Daughterboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
59
All Time:
565
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If you have identified an issue with your speaker’s daughterboard and need to replace it, use this guide to locate the daughterboard. In order to locate, remove, and replace the daughterboard of your MPOW MPBH063 speaker, you will need a JIS #00 head screwdriver, iFixit tech knife, and a metal spudger.
Parts
Tools
    1. Mpow MPBH063 Daughterboard Replacement, Daughterboard: step 1, image 1 of 1
      • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
      • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
      Ask FixBot
    2. Mpow MPBH063 Daughterboard Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Remove four JIS J00 12mm screws.
      • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
      Ask FixBot
    3. Mpow MPBH063 Daughterboard Replacement: step 3, image 1 of 1
      • Unplug the wire connected to the daughterboard.
      Ask FixBot
    4. Mpow MPBH063 Daughterboard Replacement: step 4, image 1 of 1
      • Remove the silver 10 mm screw from the center of the daughterboard.
      Ask FixBot
    5. Mpow MPBH063 Daughterboard Replacement: step 5, image 1 of 2 Mpow MPBH063 Daughterboard Replacement: step 5, image 2 of 2
      • Remove the daughterboard by carefully lifting the daughterboard out of the speaker with the metal spudger.
      • Use iFixit adhesive remover as directed
      • Before you remove the daughterboard, cut around the edges using the tech knife, and remove the adhesive securing the daughterboard to the speaker.
      Ask FixBot
Jazely Barrera
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 59
All Time: 565
