Mpow MPBH063 Battery Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
73
All Time:
4,917
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you have identified an issue with your speaker’s battery and need to replace it, use this guide to locate the battery. In order to locate, remove, and replace the battery of your MPOW Armor speaker, you will need a T6 and JIS #00 head screwdriver.
Parts
Tools
    1. Mpow MPBH063 Battery Replacement, Battery: step 1, image 1 of 3 Mpow MPBH063 Battery Replacement, Battery: step 1, image 2 of 3 Mpow MPBH063 Battery Replacement, Battery: step 1, image 3 of 3
      • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
      • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
      Ask FixBot
    2. Mpow MPBH063 Battery Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Remove four JIS J00 12mm screws.
      • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
      Ask FixBot
    3. Mpow MPBH063 Battery Replacement: step 3, image 1 of 1
      • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
      • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
      • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
      Ask FixBot
    4. Mpow MPBH063 Battery Replacement: step 4, image 1 of 1
      • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
      Ask FixBot
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
Lianna Cook
272 Reputation
2 Guides authored
2 Guide Comments
Where can I find a replacement battery for this speaker?
Sean DuBois - Reply Share
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 73
All Time: 4,917
