Up to 20% off select tools
Mpow 059 Battery Replacement
Views: 8.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
130
All Time:
8,853
Comments: 11
3 comments on steps, 8 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Find out how to change the battery in your Mpow 059 Headphones. The battery is located in the left ear cup and is simple to replace. This repair may be necessary if your batteries are no longer working and it may affect the noise cancellation, signal transmission, and audio drivers.
Note: If possible, make sure your battery is completely depleted before replacing it. If a lithium-ion battery is punctured during replacement, it may spark and create a fire.
    1. Mpow 059 Battery  Replacement, Ear Cushion: step 1, image 1 of 2 Mpow 059 Battery  Replacement, Ear Cushion: step 1, image 2 of 2
      • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
      • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
      • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
      • Applying too much pressure can damage ear cushion.
      Ask FixBot
    2. Mpow 059 Battery  Replacement: step 2, image 1 of 1
      • Remove the ear cushion away from the speaker to completely detach it from the headphones.
      Ask FixBot
    1. Mpow 059 Battery  Replacement, Battery: step 3, image 1 of 2 Mpow 059 Battery  Replacement, Battery: step 3, image 2 of 2
      • Use the Phillips #1 screwdriver to remove the six screws holding the red plastic cover in place.
      • Carefully peel the plastic cover off the left cup to reveal the ear cup's internal components.
      • There is some adhesive holding the red cover down so be careful as you remove it so it doesn't break or crack.
      Ask FixBot
    2. Mpow 059 Battery  Replacement: step 4, image 1 of 1
      • Use the JIS J00 screwdriver to remove the 3 screws that secure the black cover.
      Ask FixBot
    3. Mpow 059 Battery  Replacement: step 5, image 1 of 1
      • Remove the black cover to reveal the battery. The battery is attached to the back of the black cover.
      • The plastic cover of the headphones is connected to the battery housing by a wire connector. Be careful not to harm this cable by pulling the cap too hard during disassembly.
      • Undo the cable and remove the battery.
      Ask FixBot
7 other people completed this guide.
Author
with
Danielle Furtado
511 Reputation
2 Guides authored
8 Guide Comments
Hello
What kind of glue should I use to put new pad?
Martin Dromigny - Reply Share
What is the part number for the replacement battery? Where can I find one?
hdm_1@comcast.net - Reply Share
Battery is a 503030 3.7v 420mAh
Mark Jobe - Reply Share
First, you need to pry the piece behind the R headphone, which is itself adhered. THEN you need to pry the battery off of the backing.
And finally, you can realize you did all of this for nothing if you don't know how to solder. The battery cables are soldered onto the chip, making it impossible to replace without soldering in the replacement wires.
biggles1701 bob - Reply Share
This is good to know. I was thinking there was something missing as to how the battery is connected. While I'd like to save my headphones from the landfill, it looks like a case of planned obsolescence. Guess I'll be hunting for new headphones with better repair-ability
Nell - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 130
All Time: 8,853
