Mouse middle button replacement on Asus ROG Gladius II
  1. Mouse middle button replacement on Asus ROG Gladius II, middle button: step 1, image 1 of 2 Mouse middle button replacement on Asus ROG Gladius II, middle button: step 1, image 2 of 2
    • Remove the screw taps, and then the screws themselves.
    Ask FixBot
  2. Mouse middle button replacement on Asus ROG Gladius II: step 2, image 1 of 1
    • Open the mouse
    Ask FixBot
  3. Mouse middle button replacement on Asus ROG Gladius II: step 3, image 1 of 2 Mouse middle button replacement on Asus ROG Gladius II: step 3, image 2 of 2
    • Remove the four screws holding the wheel assembly
    Ask FixBot
  4. Mouse middle button replacement on Asus ROG Gladius II: step 4, image 1 of 2 Mouse middle button replacement on Asus ROG Gladius II: step 4, image 2 of 2
    • Remove the wheel assembly
    • remove the RGB lights from within the wheel
    Ask FixBot
  5. Mouse middle button replacement on Asus ROG Gladius II: step 5, image 1 of 2 Mouse middle button replacement on Asus ROG Gladius II: step 5, image 2 of 2
    • Remove the wheel from the wheel assembly
    Ask FixBot
  6. Mouse middle button replacement on Asus ROG Gladius II: step 6, image 1 of 2 Mouse middle button replacement on Asus ROG Gladius II: step 6, image 2 of 2
    • Unsolder the button (on the opposite side of the rotary encoder)
    Ask FixBot
  7. Mouse middle button replacement on Asus ROG Gladius II: step 7, image 1 of 2 Mouse middle button replacement on Asus ROG Gladius II: step 7, image 2 of 2
    • Place the new button and solder it
    Ask FixBot
  8. Mouse middle button replacement on Asus ROG Gladius II: step 8, image 1 of 2 Mouse middle button replacement on Asus ROG Gladius II: step 8, image 2 of 2
    • The result can be checked for connectivity
    Ask FixBot
cassisbonbon
424 Reputation
2 Guides authored
1 Guide Comment
The switch shown and listed is indeed for a Panasonic EVQ-P0E07K, except the Gladius II has a slightly differently designed switch. In the screenshots of the guide we can see the Panasonic EVQ-P0E07K has a little horizontal bar that sticks up out of the switch... but the stock OEM Gladius II has a flat-top circular button switch that rises out of the frame. The problem with this is that the round peg sticking out of the right-side of the mouse wheel runs the length of this 'bar' and it may be prone to slipping out from under the round peg with this type of a switch.
I haven't taken enough of my mouse apart yet but if I can find the proper switch number to match the OEM part, I'll post it here if possible. You might want to re-view the part information as well @cassisbonbon
Jon - Reply Share
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 119
All Time: 2,251
