Motorola syn1654A Speaker Module Replacement
    1. Motorola syn1654A Speaker Module Replacement, Speaker Module: step 1, image 1 of 2 Motorola syn1654A Speaker Module Replacement, Speaker Module: step 1, image 2 of 2
      • See the speaker replacement guide and follow steps 1 and 2.
      Ask FixBot
    2. Motorola syn1654A Speaker Module Replacement: step 2, image 1 of 1
      • Use the T6 torx screwdriver to remove the seven screws located around the headphone cover and place the screws in a safe place.
      • To avoid stripping screws, be sure to use the right drill bit oriented perpendicular to the face of the screw.
      Ask FixBot
    3. Motorola syn1654A Speaker Module Replacement: step 3, image 1 of 1
      • Carefully lift the speaker out of its housing while leaving all wires connected.
      Ask FixBot
    4. Motorola syn1654A Speaker Module Replacement: step 4, image 1 of 1
      • Lift the module out of the headphone cup, leaving all wires attached.
      • Clip the two wires circled in orange.
      • Now that the speaker is free set it aside.
      • Clip the two wires circled in yellow.
      • Replace speaker module and solder it to the two wires circled in orange.
      • Now solder the speaker wires (circled in yellow) back to the module.
      • For soldering see the ifixit soldering guide: How To Solder and Desolder Connections
      Ask FixBot
Ben
104 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 32
All Time: 661
