Up to 20% off select tools
Motorola i90c speaker replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
18
All Time:
1,590
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
Today we are going to repair the speaker system in the phone. This may be due to simple wire disconnections and may require soldering or a replacement of the system.
    1. Motorola i90c speaker replacement, Battery: step 1, image 1 of 3 Motorola i90c speaker replacement, Battery: step 1, image 2 of 3 Motorola i90c speaker replacement, Battery: step 1, image 3 of 3
      • Slide the notch downward while pulling the back cover off to remove it.
      Ask FixBot
    2. Motorola i90c speaker replacement: step 2, image 1 of 3 Motorola i90c speaker replacement: step 2, image 2 of 3 Motorola i90c speaker replacement: step 2, image 3 of 3
      • Use your fingers to push the battery upward from the bottom.
      • Lift upwards to remove the battery.
      Ask FixBot
    1. Motorola i90c speaker replacement, Antenna: step 3, image 1 of 2 Motorola i90c speaker replacement, Antenna: step 3, image 2 of 2
      • Unscrew the antenna in a counter-clockwise fashion.
      • Remove the aluminum cover.
      Ask FixBot
    1. Motorola i90c speaker replacement, Midframe: step 4, image 1 of 3 Motorola i90c speaker replacement, Midframe: step 4, image 2 of 3 Motorola i90c speaker replacement, Midframe: step 4, image 3 of 3
      • Unscrew the 3 screws shown.
      • Lift the right part of the Nextel logo
      • Remove the screw underneath.
      Ask FixBot
    2. Motorola i90c speaker replacement: step 5, image 1 of 2 Motorola i90c speaker replacement: step 5, image 2 of 2
      • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
      • Gently lift the back cover off.
      Ask FixBot
    3. Motorola i90c speaker replacement: step 6, image 1 of 3 Motorola i90c speaker replacement: step 6, image 2 of 3 Motorola i90c speaker replacement: step 6, image 3 of 3
      • Find the connection between the headphone jack and logic board.
      • Begin separating the two pieces, slowly and carefully.
      Ask FixBot
    1. Motorola i90c speaker replacement, Speaker System: step 7, image 1 of 3 Motorola i90c speaker replacement, Speaker System: step 7, image 2 of 3 Motorola i90c speaker replacement, Speaker System: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use the prying tools to wedge out the circular part of the speaker system.
      • Carefully pull out the wiring and circuit board attached to the speaker system using a prying tool or tweezers.
      Ask FixBot
Author
with
Jorge
4 Reputation
4 Guides authored
Cal Poly, Team 29-61, Johann Spring 2010 Member of Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 1,590
