Motorola i90c Antenna Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
16
Past 30 Days:
52
All Time:
3,151
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
How to replace a damaged antenna.
    1. Motorola i90c Antenna Replacement, Battery: step 1, image 1 of 3 Motorola i90c Antenna Replacement, Battery: step 1, image 2 of 3 Motorola i90c Antenna Replacement, Battery: step 1, image 3 of 3
      • Slide the notch downward while pulling the back cover off to remove it.
      Ask FixBot
    2. Motorola i90c Antenna Replacement: step 2, image 1 of 3 Motorola i90c Antenna Replacement: step 2, image 2 of 3 Motorola i90c Antenna Replacement: step 2, image 3 of 3
      • Use your fingers to push the battery upward from the bottom.
      • Lift upwards to remove the battery.
      Ask FixBot
    1. Motorola i90c Antenna Replacement, Antenna: step 3, image 1 of 2 Motorola i90c Antenna Replacement, Antenna: step 3, image 2 of 2
      • Unscrew the antenna in a counter-clockwise fashion.
      • Remove the aluminum cover.
      Ask FixBot
Jorge
4 Reputation
4 Guides authored
Cal Poly, Team 29-61, Johann Spring 2010 Member of Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 52
All Time: 3,151
