Motorola i850 LCD Screen Replacement
    1. Motorola i850 LCD Screen Replacement, LCD Board: step 1, image 1 of 1
      • Open the flip cover of the phone with the LCD screen facing towards you.
      Ask FixBot
    2. Motorola i850 LCD Screen Replacement: step 2, image 1 of 2 Motorola i850 LCD Screen Replacement: step 2, image 2 of 2
      • Use a Razor Blade to remove the screw covers.
      • Razor Blade is very sharp. Use caution.
      Ask FixBot
    3. Motorola i850 LCD Screen Replacement: step 3, image 1 of 1
      • Unscrew the screws using a Phillips #00 Screwdriver.
      Ask FixBot
    4. Motorola i850 LCD Screen Replacement: step 4, image 1 of 1
      • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
      Ask FixBot
    5. Motorola i850 LCD Screen Replacement: step 5, image 1 of 1
      • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
      Ask FixBot
    6. Motorola i850 LCD Screen Replacement: step 6, image 1 of 1
      • Partially close the flip cover of the phone in order to take off the outer case.
      Ask FixBot
    7. Motorola i850 LCD Screen Replacement: step 7, image 1 of 1
      • Completely remove the outer casing from the phone.
      Ask FixBot
    8. Motorola i850 LCD Screen Replacement: step 8, image 1 of 2 Motorola i850 LCD Screen Replacement: step 8, image 2 of 2
      • Place your thumb underneath the protective metal covering to remove it from the phone.
      Ask FixBot
    9. Motorola i850 LCD Screen Replacement: step 9, image 1 of 1
      • Gently detach the black microchip from the phone with a Tweezer.
      Ask FixBot
    10. Motorola i850 LCD Screen Replacement: step 10, image 1 of 1
      • Prop out the LCD board from the phone using your fingertips.
      Ask FixBot
    11. Motorola i850 LCD Screen Replacement: step 11, image 1 of 2 Motorola i850 LCD Screen Replacement: step 11, image 2 of 2
      • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
      Ask FixBot
    1. Motorola i850 LCD Screen Replacement, LCD Screen: step 12, image 1 of 1
      • Firmly detach the gold strip using a Tweezer.
      Ask FixBot
    2. Motorola i850 LCD Screen Replacement: step 13, image 1 of 1
      • Prop out the LCD screen using a Small Flathead Screwdriver.
      Ask FixBot
    3. Motorola i850 LCD Screen Replacement: step 14, image 1 of 3 Motorola i850 LCD Screen Replacement: step 14, image 2 of 3 Motorola i850 LCD Screen Replacement: step 14, image 3 of 3
      • Remove the LCD screen from the LCD board.
      Ask FixBot
Andrew Aw
1 Reputation
2 Guides authored
Cal Poly, Team 34-56, Forte Spring 2010 Member of Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 29
All Time: 2,482
