Motorola i710 Charger Plug Replacement
    1. Motorola i710 Charger Plug Replacement, Battery Cover: step 1, image 1 of 2 Motorola i710 Charger Plug Replacement, Battery Cover: step 1, image 2 of 2
      • Slide the cover release button towards the bottom of the phone
      • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 Charger Plug Replacement, Battery: step 2, image 1 of 1
      • Push the battery towards the top of the phone and lift up.
      Ask FixBot
    1. Motorola i710 Charger Plug Replacement, Back Casing: step 3, image 1 of 3 Motorola i710 Charger Plug Replacement, Back Casing: step 3, image 2 of 3 Motorola i710 Charger Plug Replacement, Back Casing: step 3, image 3 of 3
      • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
      • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
      Ask FixBot
    1. Motorola i710 Charger Plug Replacement, Charger Plug: step 4, image 1 of 1
      • Once you have taken off the back cover of the phone, the charger tab can be lifted out of position on the back cover.
      Ask FixBot
Caitlin Smith
4 Reputation
2 Guides authored
Clemson, Team 14-2, Benson Fall 2012 Member of Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Members
143 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 744
