Up to 20% off select tools
Motorola i560 Microphone Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
20
All Time:
548
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Removing the speaker requires the removal of the motherboard, which requires nearly a full dis-assembly of the phone.
    1. Motorola i560 Microphone Replacement, Battery: step 1, image 1 of 1
      • Place thumb on the rubber tab on the lower back of the phone.
      • Push away from the phone to release back panel.
      Ask FixBot
    2. Motorola i560 Microphone Replacement: step 2, image 1 of 1
      • Lift the back panel of the phone to expose battery (not shown here).
      Ask FixBot
    1. Motorola i560 Microphone Replacement, Side Volume Button: step 3, image 1 of 1
      • Pull antenna up, away from the phone, to reveal two of six screws.
      Ask FixBot
    2. Motorola i560 Microphone Replacement: step 4, image 1 of 1
      • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
      Ask FixBot
    3. Motorola i560 Microphone Replacement: step 5, image 1 of 2 Motorola i560 Microphone Replacement: step 5, image 2 of 2
      • Gently separate the front and back sides of the phone.
      • Be careful not to break or bend the ribbon cables.
      Ask FixBot
    4. Motorola i560 Microphone Replacement: step 6, image 1 of 2 Motorola i560 Microphone Replacement: step 6, image 2 of 2
      • Detach the first ribbon cable by unplugging it from the logic board.
      Ask FixBot
    5. Motorola i560 Microphone Replacement: step 7, image 1 of 3 Motorola i560 Microphone Replacement: step 7, image 2 of 3 Motorola i560 Microphone Replacement: step 7, image 3 of 3
      • Gently remove the side button by pulling the buttons away from the phone.
      Ask FixBot
    1. Motorola i560 Microphone Replacement, Metal Support Plate: step 8, image 1 of 3 Motorola i560 Microphone Replacement, Metal Support Plate: step 8, image 2 of 3 Motorola i560 Microphone Replacement, Metal Support Plate: step 8, image 3 of 3
      • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
      Ask FixBot
    1. Motorola i560 Microphone Replacement, Microphone: step 9, image 1 of 3 Motorola i560 Microphone Replacement, Microphone: step 9, image 2 of 3 Motorola i560 Microphone Replacement, Microphone: step 9, image 3 of 3
      • Slightly bend the phone frame to expose microphone protrusion.
      • Gently remove microphone using your fingers.
      Ask FixBot
    2. Motorola i560 Microphone Replacement: step 10, image 1 of 1
      • Once the microphone has been removed, remove the connecting piece
      Ask FixBot
Author
with
Haley S
10 Reputation
4 Guides authored
Clemson, Team 13-6, Benson Spring 2013 Member of Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 548
