Up to 20% off select tools
Motorola i560 Keypad Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
16
All Time:
486
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Keypad installation can be used to replace a worn keypad or a keypad that is misaligned.
    1. Motorola i560 Keypad Replacement, Battery: step 1, image 1 of 1
      • Place thumb on the rubber tab on the lower back of the phone.
      • Push away from the phone to release back panel.
      Ask FixBot
    2. Motorola i560 Keypad Replacement: step 2, image 1 of 1
      • Lift the back panel of the phone to expose battery (not shown here).
      Ask FixBot
    1. Motorola i560 Keypad Replacement, Motherboard: step 3, image 1 of 1
      • Pull the antenna up to reveal two of the six screws.
      Ask FixBot
    2. Motorola i560 Keypad Replacement: step 4, image 1 of 1
      • Unscrew all six screws on the back side of the phone using a T-6 bit.
      Ask FixBot
    3. Motorola i560 Keypad Replacement: step 5, image 1 of 2 Motorola i560 Keypad Replacement: step 5, image 2 of 2
      • Gently separate the front and back sides of the phone, as shown in the picture.
      • Be careful not to break or bend the ribbon cables.
      Ask FixBot
    4. Motorola i560 Keypad Replacement: step 6, image 1 of 2 Motorola i560 Keypad Replacement: step 6, image 2 of 2
      • Detach the first ribbon cable by unplugging it from the motherboard.
      Ask FixBot
    5. Motorola i560 Keypad Replacement: step 7, image 1 of 2 Motorola i560 Keypad Replacement: step 7, image 2 of 2
      • Detach the speaker ribbon cable from the motherboard.
      Ask FixBot
    6. Motorola i560 Keypad Replacement: step 8, image 1 of 1
      • Remove the motherboard from the front half of the phone by gently shaking it loose. It should come out with little to no trouble.
      Ask FixBot
    1. Motorola i560 Keypad Replacement, Keypad: step 9, image 1 of 1
      • Push lightly from the front of the keypad to remove it.
      Ask FixBot
Author
with
Haley S
10 Reputation
4 Guides authored
Clemson, Team 13-6, Benson Spring 2013 Member of Clemson, Team 13-6, Benson Spring 2013
CLEM-BENSON-S13S13G6
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 486
