Up to 20% off select tools
Motorola i1000plus Microphone Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
99
All Time:
922
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
As with all electronic devices, microphones will eventually stop functioning properly and need replacement. This guide will show the user how to replace the microphone in their device. This guide requires little to no technical knowledge and is easy to complete. Anyone should be able to follow this guide.
    1. Motorola i1000plus Microphone Replacement, Battery: step 1, image 1 of 3 Motorola i1000plus Microphone Replacement, Battery: step 1, image 2 of 3 Motorola i1000plus Microphone Replacement, Battery: step 1, image 3 of 3
      • Be sure phone is powered off before removing the battery.
      • Push the tab located at the bottom of the battery towards the top of the phone.
      • Lift the battery away from the phone.
      Ask FixBot
    1. Motorola i1000plus Microphone Replacement, Antenna: step 2, image 1 of 3 Motorola i1000plus Microphone Replacement, Antenna: step 2, image 2 of 3 Motorola i1000plus Microphone Replacement, Antenna: step 2, image 3 of 3
      • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
      • Pull the antenna straight out of the phone.
      Ask FixBot
    1. Motorola i1000plus Microphone Replacement, Back Cover: step 3, image 1 of 3 Motorola i1000plus Microphone Replacement, Back Cover: step 3, image 2 of 3 Motorola i1000plus Microphone Replacement, Back Cover: step 3, image 3 of 3
      • Pry off the bottom piece using the spudger.
      • There are notches on the edge of this piece that can be used to aid prying.
      Ask FixBot
    2. Motorola i1000plus Microphone Replacement: step 4, image 1 of 1
      • Remove the sticker overlaying the NEXTEL logo.
      Ask FixBot
    3. Motorola i1000plus Microphone Replacement: step 5, image 1 of 1
      • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
      Ask FixBot
    4. Motorola i1000plus Microphone Replacement: step 6, image 1 of 3 Motorola i1000plus Microphone Replacement: step 6, image 2 of 3 Motorola i1000plus Microphone Replacement: step 6, image 3 of 3
      • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
      Ask FixBot
    1. Motorola i1000plus Microphone Replacement, Motherboard: step 7, image 1 of 1
      • Using a Torx T8 screwdriver, remove the two circled screws by unscrewing counterclockwise.
      Ask FixBot
    2. Motorola i1000plus Microphone Replacement: step 8, image 1 of 3 Motorola i1000plus Microphone Replacement: step 8, image 2 of 3 Motorola i1000plus Microphone Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Using a pair of tweezers, firmly grasp the connector at the top of the phone and pull the connector straight away from the phone.
      • Do not pull the connector off by the wire. This could damage or destroy the wire or connector.
      Ask FixBot
    3. Motorola i1000plus Microphone Replacement: step 9, image 1 of 2 Motorola i1000plus Microphone Replacement: step 9, image 2 of 2
      • Unclip the ribbon cable, located underneath the motherboard, by using the spudger to push up on the dark brown part of the connector located on the circuit board.
      • Do not pull the motherboard too far away from the phone with the ribbon cable still connected. this will damage the cable or the motherboard.
      Ask FixBot
    4. Motorola i1000plus Microphone Replacement: step 10, image 1 of 2 Motorola i1000plus Microphone Replacement: step 10, image 2 of 2
      • Remove the motherboard by firmly grasping the edges of the circuit board with one hand and the phone with the other and pulling up on the motherboard slightly and then pulling it straight down toward the bottom of the phone.
      • Be sure to pull straight down to disconnect the ribbon cable properly. Pulling in another direction may cause damage to the cable or the motherboard.
      Ask FixBot
    1. Motorola i1000plus Microphone Replacement, Keypad Circuit Board: step 11, image 1 of 3 Motorola i1000plus Microphone Replacement, Keypad Circuit Board: step 11, image 2 of 3 Motorola i1000plus Microphone Replacement, Keypad Circuit Board: step 11, image 3 of 3
      • Flip the motherboard over 180 degrees.
      • Place a spudger in between the gold plate and the bottom of the circuit board.
      • Carefully use the spudger as a prying tool to lift the circuit board from the motherboard.
      • Be very careful not to insert the spudger too far or to apply too much pressure. It can easily damage the circuit board.
      Ask FixBot
    1. Motorola i1000plus Microphone Replacement, Microphone: step 12, image 1 of 3 Motorola i1000plus Microphone Replacement, Microphone: step 12, image 2 of 3 Motorola i1000plus Microphone Replacement, Microphone: step 12, image 3 of 3
      Buy
      • Flip the keypad circuit board over so the keys are facing the table.
      • Using pair of tweezers, remove the black plastic piece holding the microphone in place.
      Ask FixBot
    2. Motorola i1000plus Microphone Replacement: step 13, image 1 of 2 Motorola i1000plus Microphone Replacement: step 13, image 2 of 2
      • Flip the keypad circuit board over again so the keys are now facing away from the table.
      • Using a pair of tweezers, remove the microphone from the circuit board.
      Ask FixBot
Author
with
Matthew Byrd
401 Reputation
4 Guides authored
Clemson, Team 13-3, Benson Fall 2013 Member of Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 99
All Time: 922
