Motorola i1000plus Back Cover Replacement
    1. Motorola i1000plus Back Cover Replacement, Battery: step 1, image 1 of 3 Motorola i1000plus Back Cover Replacement, Battery: step 1, image 2 of 3 Motorola i1000plus Back Cover Replacement, Battery: step 1, image 3 of 3
      • Be sure phone is powered off before removing the battery.
      • Push the tab located at the bottom of the battery towards the top of the phone.
      • Lift the battery away from the phone.
      Ask FixBot
    1. Motorola i1000plus Back Cover Replacement, Antenna: step 2, image 1 of 3 Motorola i1000plus Back Cover Replacement, Antenna: step 2, image 2 of 3 Motorola i1000plus Back Cover Replacement, Antenna: step 2, image 3 of 3
      • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
      • Pull the antenna straight out of the phone.
      Ask FixBot
    1. Motorola i1000plus Back Cover Replacement, Back Cover: step 3, image 1 of 3 Motorola i1000plus Back Cover Replacement, Back Cover: step 3, image 2 of 3 Motorola i1000plus Back Cover Replacement, Back Cover: step 3, image 3 of 3
      • Pry off the bottom piece using the spudger.
      • There are notches on the edge of this piece that can be used to aid prying.
      Ask FixBot
    2. Motorola i1000plus Back Cover Replacement: step 4, image 1 of 1
      • Remove the sticker overlaying the NEXTEL logo.
      Ask FixBot
    3. Motorola i1000plus Back Cover Replacement: step 5, image 1 of 1
      • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
      Ask FixBot
    4. Motorola i1000plus Back Cover Replacement: step 6, image 1 of 3 Motorola i1000plus Back Cover Replacement: step 6, image 2 of 3 Motorola i1000plus Back Cover Replacement: step 6, image 3 of 3
      • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
      Ask FixBot
Austin Lake
501 Reputation
5 Guides authored
Clemson, Team 13-3, Benson Fall 2013 Member of Clemson, Team 13-3, Benson Fall 2013
CLEM-BENSON-F13S13G3
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 30
All Time: 511
