Motorola Xoom Wifi Back Cover Disassembly
    1. Motorola Xoom Wifi Back Cover Disassembly, Back Cover Disassembly: step 1, image 1 of 2 Motorola Xoom Wifi Back Cover Disassembly, Back Cover Disassembly: step 1, image 2 of 2
      • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
      Ask FixBot
    2. Motorola Xoom Wifi Back Cover Disassembly: step 2, image 1 of 2 Motorola Xoom Wifi Back Cover Disassembly: step 2, image 2 of 2
      • Apply light pressure with hand and slide the back plate till it stops in this position.
      • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
      • As soon as the clips are released the back should slide off.
      Ask FixBot
    3. Motorola Xoom Wifi Back Cover Disassembly: step 3, image 1 of 3 Motorola Xoom Wifi Back Cover Disassembly: step 3, image 2 of 3 Motorola Xoom Wifi Back Cover Disassembly: step 3, image 3 of 3
      • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
      • Once both screws are taken out, lift the rest of the backing out of the way.
      Ask FixBot
4 other people completed this guide.
Mallika
464 Reputation
2 Guides authored
Cal Poly, Team 3-39, Maness Spring 2014 Member of Cal Poly, Team 3-39, Maness Spring 2014
CPSU-MANESS-S14S3G39
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,786
