Motorola Xoom 2 MotherBoard Replacement
    1. Motorola Xoom 2 MotherBoard Replacement, Backplate: step 1, image 1 of 3 Motorola Xoom 2 MotherBoard Replacement, Backplate: step 1, image 2 of 3 Motorola Xoom 2 MotherBoard Replacement, Backplate: step 1, image 3 of 3
      • Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
      Ask FixBot
    2. Motorola Xoom 2 MotherBoard Replacement: step 2, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement: step 2, image 2 of 2
      • Using a T5 screwdriver, unscrew the four 1.5mm screws holding the main back cover. These screws are arranged in a line across the top of the back of the device.
      Ask FixBot
    3. Motorola Xoom 2 MotherBoard Replacement: step 3, image 1 of 3 Motorola Xoom 2 MotherBoard Replacement: step 3, image 2 of 3 Motorola Xoom 2 MotherBoard Replacement: step 3, image 3 of 3
      • Turn the device over and using a pry tool and the opening picks, gently apply pressure between the outside edge of the seal marked with the arrow. Slowly move around the edges of the device, applying even pressure, and separate the back plate from the display.
      • There is adhesive between the back-plate and battery.
      Ask FixBot
    4. Motorola Xoom 2 MotherBoard Replacement: step 4, image 1 of 1
      • Remove the back plate from your device.
      Ask FixBot
    1. Motorola Xoom 2 MotherBoard Replacement, Rear-Facing Camera: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, remove the blue Kapton tape.
      • Set this piece aside as it is required for reassembly.
      Ask FixBot
    2. Motorola Xoom 2 MotherBoard Replacement: step 6, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement: step 6, image 2 of 2
      • Using a spudger, carefully pry and remove camera assembly using the small pry point as shown.
      • After removing the camera from the housing, use tweezers and pull gently to remove the connector from its housing.
      Ask FixBot
    1. Motorola Xoom 2 MotherBoard Replacement, Speaker: step 7, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement, Speaker: step 7, image 2 of 2
      Buy
      • Using tweezers or a prying tool, gently disconnect the speaker connector cable from the motherboard.
      • Check to make sure that red is on the right and black is on the left.
      Ask FixBot
    2. Motorola Xoom 2 MotherBoard Replacement: step 8, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement: step 8, image 2 of 2
      • Using a prying tool or a spudger, gently apply pressure to the gap between the speaker and the plastic chassis and lift the speaker out of the device.
      • The speakers are held in place by a piece of tape.
      Ask FixBot
    1. Motorola Xoom 2 MotherBoard Replacement, Motherboard: step 9, image 1 of 1
      • Disconnect the connectors highlighted in the photo. Shown here in boxes.
      • We will disconnect these components in order of color. Remember ROY G BIV!
      Ask FixBot
    2. Motorola Xoom 2 MotherBoard Replacement: step 10, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement: step 10, image 2 of 2
      • Disconnect the battery first for safety by unscrewing the two 1.5mm screws with a T5 Torx screwdriver.
      • Following best safety practices, insulate the red positive lead by wrapping the connector with any form of non-conductive tape, such as masking tape or electrical tape.
      Ask FixBot
    3. Motorola Xoom 2 MotherBoard Replacement: step 11, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement: step 11, image 2 of 2
      • The following steps will take place within the outlined red sector.
      • The connectors will be removed in this order: red, orange, yellow, then green.
      Ask FixBot
    4. Motorola Xoom 2 MotherBoard Replacement: step 12, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement: step 12, image 2 of 2
      • Begin by removing this three-wire connector with a spudger or similar pry tool as shown.
      • Next remove the smaller two-wire connector in the same way as the first.
      • The connectors come out by being pulled up and not pulled out.
      Ask FixBot
    5. Motorola Xoom 2 MotherBoard Replacement: step 13, image 1 of 1
      • Using a prying tool or a spudger, disconnect the following connectors by applying upward force from underneath the connections.
      • Be gentle when pulling the connections out, making sure not to damage any.
      Ask FixBot
    6. Motorola Xoom 2 MotherBoard Replacement: step 14, image 1 of 3 Motorola Xoom 2 MotherBoard Replacement: step 14, image 2 of 3 Motorola Xoom 2 MotherBoard Replacement: step 14, image 3 of 3
      Buy
      • Using your fingers, gently pull back the connector. Using tweezers pull up the 'handle' of the connector located underneath. This handle is resting in front of the yellow-gold metal strip where the wires meet.
      • Once the handle has been pulled up and rotated back to a more accessible position, you will be able to grab it with your fingers. Pull the handle back to disconnect it from the device.
      Ask FixBot
    7. Motorola Xoom 2 MotherBoard Replacement: step 15, image 1 of 2 Motorola Xoom 2 MotherBoard Replacement: step 15, image 2 of 2
      • Using a pair of tweezers, carefully pry up the black plastic connector holding the cable.
      Ask FixBot
    8. Motorola Xoom 2 MotherBoard Replacement: step 16, image 1 of 1
      • Remove the following six 1.5mm screws using a T5 Torx screwdriver.
      • Once all connectors and screws have been removed from the motherboard, it is ready to be pried up and removed.
      Ask FixBot
    9. Motorola Xoom 2 MotherBoard Replacement: step 17, image 1 of 3 Motorola Xoom 2 MotherBoard Replacement: step 17, image 2 of 3 Motorola Xoom 2 MotherBoard Replacement: step 17, image 3 of 3
      • Begin prying up the motherboard in the corner nearest the battery. Not much force will be required as the board is completely loose at this point.
      • Next, pry the motherboard up at the top of the device near the left speaker.
      • Once you can get the edge of the board high enough, grab it and lift it up and towards the battery. This will prevent it from snagging on the cable disconnected in step 7.
      Ask FixBot
    10. Motorola Xoom 2 MotherBoard Replacement: step 18, image 1 of 1
      • Remove the motherboard from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Leave the battery unplugged until the back plate need to be added on.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 23
All Time: 683
