Motorola Xoom 2 Battery Replacement
    1. Motorola Xoom 2 Battery Replacement, Backplate: step 1, image 1 of 3 Motorola Xoom 2 Battery Replacement, Backplate: step 1, image 2 of 3 Motorola Xoom 2 Battery Replacement, Backplate: step 1, image 3 of 3
      • Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
      Ask FixBot
    2. Motorola Xoom 2 Battery Replacement: step 2, image 1 of 2 Motorola Xoom 2 Battery Replacement: step 2, image 2 of 2
      • Using a T5 screwdriver, unscrew the four 1.5mm screws holding the main back cover. These screws are arranged in a line across the top of the back of the device.
      Ask FixBot
    3. Motorola Xoom 2 Battery Replacement: step 3, image 1 of 3 Motorola Xoom 2 Battery Replacement: step 3, image 2 of 3 Motorola Xoom 2 Battery Replacement: step 3, image 3 of 3
      • Turn the device over and using a pry tool and the opening picks, gently apply pressure between the outside edge of the seal marked with the arrow. Slowly move around the edges of the device, applying even pressure, and separate the back plate from the display.
      • There is adhesive between the back-plate and battery.
      Ask FixBot
    4. Motorola Xoom 2 Battery Replacement: step 4, image 1 of 1
      • Remove the back plate from your device.
      Ask FixBot
    1. Motorola Xoom 2 Battery Replacement, Battery: step 5, image 1 of 2 Motorola Xoom 2 Battery Replacement, Battery: step 5, image 2 of 2
      • Using a Torx T5 screwdriver, remove the four 1.5mm screws holding down the battery around its perimeter.
      Ask FixBot
    2. Motorola Xoom 2 Battery Replacement: step 6, image 1 of 3 Motorola Xoom 2 Battery Replacement: step 6, image 2 of 3 Motorola Xoom 2 Battery Replacement: step 6, image 3 of 3
      • Using a Torx T5 screwdriver remove the two 1.5mm screws holding down the battery leads and carefully pry the battery leads loose from the cable clips with a spudger.
      • Following best safety practices, insulate the red positive lead by wrapping the connector with any form of non-conductive tape, such as masking tape or electrical tape.
      Ask FixBot
    3. Motorola Xoom 2 Battery Replacement: step 7, image 1 of 3 Motorola Xoom 2 Battery Replacement: step 7, image 2 of 3 Motorola Xoom 2 Battery Replacement: step 7, image 3 of 3
      • Lifting gently from the bottom with a spudger, first disconnect the three pin connector from the tablet.
      • After disconnecting the three pin connector, remove the two pin battery connector by lifting gently from the bottom with a spudger.
      • Be careful not to use too much force! The connectors used are made of soft plastic and can break easily.
      Ask FixBot
    4. Motorola Xoom 2 Battery Replacement: step 8, image 1 of 2 Motorola Xoom 2 Battery Replacement: step 8, image 2 of 2
      • Using the opening picks, carefully lift the battery and remove it from the device.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Looks great, loving all the work you guys
Enrique Escobar - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 997
