Up to 20% off select tools
Motorola W490 Keypad Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
89
All Time:
1,151
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Motorola W490 Keypad Replacement, Phone Casing: step 1, image 1 of 2 Motorola W490 Keypad Replacement, Phone Casing: step 1, image 2 of 2
      • Pick up the cell phone with the back facing towards you.
      • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
      • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
      Ask FixBot
    1. Motorola W490 Keypad Replacement, Battery: step 2, image 1 of 2 Motorola W490 Keypad Replacement, Battery: step 2, image 2 of 2
      • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
      • Set the battery aside.
      Ask FixBot
    1. Motorola W490 Keypad Replacement, SIM Card: step 3, image 1 of 3 Motorola W490 Keypad Replacement, SIM Card: step 3, image 2 of 3 Motorola W490 Keypad Replacement, SIM Card: step 3, image 3 of 3
      • Use a plastic opening tool to make a gap between the SIM card and the phone.
      • Use your thumb and index finger to pull the SIM card from the phone.
      Ask FixBot
    1. Motorola W490 Keypad Replacement, Keypad Membrane: step 4, image 1 of 1
      • Open phone so the keypad is facing up.
      Ask FixBot
    2. Motorola W490 Keypad Replacement: step 5, image 1 of 1
      • Insert a push pin into the notch located on the left side of the keypad and push the pin under the keypad membrane.
      Ask FixBot
    3. Motorola W490 Keypad Replacement: step 6, image 1 of 1
      • Continue working the pin under the keypad membrane until it is elevated enough to grasp.
      Ask FixBot
    4. Motorola W490 Keypad Replacement: step 7, image 1 of 1
      • Grasp the keypad membrane firmly and remove it from the phone.
      Ask FixBot
    1. Motorola W490 Keypad Replacement, Lower Metal Frame: step 8, image 1 of 2 Motorola W490 Keypad Replacement, Lower Metal Frame: step 8, image 2 of 2
      • After taking out the battery, locate four star-shaped 5.4 mm T6 screws on top and middle of the rear of the phone. Indicated by the red circles.
      • Remove all the screws using the Torx T6 Screwdriver.
      Ask FixBot
    2. Motorola W490 Keypad Replacement: step 9, image 1 of 3 Motorola W490 Keypad Replacement: step 9, image 2 of 3 Motorola W490 Keypad Replacement: step 9, image 3 of 3
      • Turn over the phone to the front side and open up the phone, displaying the keypad.
      • Use a plastic opening tool or your fingernail to make a gap between the front bottom cover and the phone.
      • Pull and set the glued plastic cover aside.
      • Be careful not to break the plastic cover when making a gap or pulling. The plastic cover is superglued to the phone.
      Ask FixBot
    3. Motorola W490 Keypad Replacement: step 10, image 1 of 2 Motorola W490 Keypad Replacement: step 10, image 2 of 2
      • Under the plastic cover, locate two star-shaped T5 screws.
      • Use the Torx T5 Screwdriver to remove the two screws.
      Ask FixBot
    4. Motorola W490 Keypad Replacement: step 11, image 1 of 3 Motorola W490 Keypad Replacement: step 11, image 2 of 3 Motorola W490 Keypad Replacement: step 11, image 3 of 3
      • Turn over the phone to the back side of phone where the battery was removed.
      • Use hands to remove the unscrewed rear frame of the phone.
      • Set aside the rear metal frame.
      Ask FixBot
    1. Motorola W490 Keypad Replacement, Circuit Board: step 12, image 1 of 3 Motorola W490 Keypad Replacement, Circuit Board: step 12, image 2 of 3 Motorola W490 Keypad Replacement, Circuit Board: step 12, image 3 of 3
      • Identify the flex cable attachment. Indicated in a red square.
      • Detach the bottom half of the flex cable, pop it off of the circuit board.
      • Pick up the loosened circuit board from the phone and set aside.
      Ask FixBot
    1. Motorola W490 Keypad Replacement, Keypad: step 13, image 1 of 3 Motorola W490 Keypad Replacement, Keypad: step 13, image 2 of 3 Motorola W490 Keypad Replacement, Keypad: step 13, image 3 of 3
      • Lay the circuit board down with the keypad facing up.
      • Grab the corner of the keypad and gently peel it away from the circuit board.
      Ask FixBot
Author
with
Will Edwards
61 Reputation
9 Guides authored
Clemson, Team 14-1, Benson Fall 2012 Member of Clemson, Team 14-1, Benson Fall 2012
CLEM-BENSON-F12S14G1
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 89
All Time: 1,151
