Up to 20% off select tools
Motorola W385 speaker replacement
Views: 3.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
88
All Time:
3,857
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • Tweezers
Introduction
Go to step 1 ↓
If you are having trouble hearing, this guide will help you replace your speaker.
    1. Motorola W385 speaker replacement, Battery: step 1, image 1 of 1
      • Using your finger, press down on the clip holding the back cover on.
      Ask FixBot
    2. Motorola W385 speaker replacement: step 2, image 1 of 1
      • Using the spudger or your finger, gently pull the battery out from the top.
      Ask FixBot
    1. Motorola W385 speaker replacement, Front Casing: step 3, image 1 of 1
      • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
      • The rubber pieces are held in with a mild adhesive.
      Ask FixBot
    2. Motorola W385 speaker replacement: step 4, image 1 of 1
      • Remove the four Torx-6 screws from underneath the rubber pieces.
      Ask FixBot
    3. Motorola W385 speaker replacement: step 5, image 1 of 2 Motorola W385 speaker replacement: step 5, image 2 of 2
      • Close the phone before proceeding.
      • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
      • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
      • Continue to move around the phone counter clockwise until the casing is separated from the body.
      • It is not unusual for it to pop off before making it back to the starting point.
      Ask FixBot
    4. Motorola W385 speaker replacement: step 6, image 1 of 1
      • If the casing has not popped off of the body, remove it carefully from the the phone.
      Ask FixBot
    1. Motorola W385 speaker replacement, Top Logic Board: step 7, image 1 of 1
      • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
      Ask FixBot
    2. Motorola W385 speaker replacement: step 8, image 1 of 3 Motorola W385 speaker replacement: step 8, image 2 of 3 Motorola W385 speaker replacement: step 8, image 3 of 3
      • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
      • Gently take off the metal casing of the logic board.
      Ask FixBot
    3. Motorola W385 speaker replacement: step 9, image 1 of 3 Motorola W385 speaker replacement: step 9, image 2 of 3 Motorola W385 speaker replacement: step 9, image 3 of 3
      • Use spudger to gently disconnect the ribbon cable from phone.
      • Gently remove Logic Board making sure not to damage any other components.
      Ask FixBot
    1. Motorola W385 speaker replacement, Main Speaker: step 10, image 1 of 1
      • Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
      Ask FixBot
    2. Motorola W385 speaker replacement: step 11, image 1 of 2 Motorola W385 speaker replacement: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Place the spudger between the speaker and the clip shown.
      • Separate the clip from the speaker while lifting on the speaker.
      • The speaker should separate. Use the tweezers to grab the speaker.
      Ask FixBot
Author
with
Koedy Brant
41 Reputation
2 Guides authored
Cal Poly, Team 8-50, Regan Winter 2010 Member of Cal Poly, Team 8-50, Regan Winter 2010
CPSU-REGAN-W10S8G50
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 88
All Time: 3,857
