Up to 20% off select tools
Motorola W315 Screen Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
87
All Time:
811
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Motorola W315 Screen Replacement, Display Cover: step 1, image 1 of 3 Motorola W315 Screen Replacement, Display Cover: step 1, image 2 of 3 Motorola W315 Screen Replacement, Display Cover: step 1, image 3 of 3
      • Insert the spudger between the silver body of the phone and the black "Verizon" display sticker.
      • Work the spudger around the extremity of the sticker.
      • Remove display sticker.
      • Be aware that if the display sticker comes back in contact with the phone it will adhere back to the phone.
      Ask FixBot
    1. Motorola W315 Screen Replacement, Screen: step 2, image 1 of 1
      • Using the T6 tool, remove the four 5mm screws on the face of the display (circled in red).Before replacing the screen, the four screws beneath the display must already be removed.
      Ask FixBot
    2. Motorola W315 Screen Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Insert the tweezers between the front and back panels of the top half of the device. Make as large a gap as possible using the tweezers.
      Ask FixBot
    3. Motorola W315 Screen Replacement: step 4, image 1 of 3 Motorola W315 Screen Replacement: step 4, image 2 of 3 Motorola W315 Screen Replacement: step 4, image 3 of 3
      • Using the Pry Bar, move around the entire edge of the the device until the two panels separate from each other.
      • Grab the plastic casing and remove
      Ask FixBot
    4. Motorola W315 Screen Replacement: step 5, image 1 of 3 Motorola W315 Screen Replacement: step 5, image 2 of 3 Motorola W315 Screen Replacement: step 5, image 3 of 3
      • Use the pry bar to lift the metal cover from the screen housing.
      Ask FixBot
    5. Motorola W315 Screen Replacement: step 6, image 1 of 2 Motorola W315 Screen Replacement: step 6, image 2 of 2
      • Pry the chip connected by magnetic strip from the back of the screen.
      • Remove display circuit board from the body of the phone.
      Ask FixBot
    6. Motorola W315 Screen Replacement: step 7, image 1 of 2 Motorola W315 Screen Replacement: step 7, image 2 of 2
      • Remove the screen from the front panel of the device.
      Ask FixBot
Author
with
Justin Scott
501 Reputation
5 Guides authored
Clemson, Team 6-3, Benson Spring 2014 Member of Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 87
All Time: 811
