Motorola V710 LCD screen replacement
Views: 2.5K
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
40
All Time:
2,470
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
How to replace the screen in the Motorola V710 phone
Tools
  • Spudger
    4.9
    1. Motorola V710 LCD screen replacement, Screen: step 1, image 1 of 3 Motorola V710 LCD screen replacement, Screen: step 1, image 2 of 3 Motorola V710 LCD screen replacement, Screen: step 1, image 3 of 3
      • Insert the spudger between the gray and black plates of the screen casing.
      • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
      • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
      Ask FixBot
    2. Motorola V710 LCD screen replacement: step 2, image 1 of 2 Motorola V710 LCD screen replacement: step 2, image 2 of 2
      • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
      • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
      • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
      Ask FixBot
    3. Motorola V710 LCD screen replacement: step 3, image 1 of 2 Motorola V710 LCD screen replacement: step 3, image 2 of 2
      • Orient the phone so that the main screen is facing upward.
      • Locate the hinge casing, a dark gray piece that covers the hinge.
      • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
      Ask FixBot
    4. Motorola V710 LCD screen replacement: step 4, image 1 of 2 Motorola V710 LCD screen replacement: step 4, image 2 of 2
      • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
      Ask FixBot
    5. Motorola V710 LCD screen replacement: step 5, image 1 of 2 Motorola V710 LCD screen replacement: step 5, image 2 of 2
      • Insert the spudger under the screen and pry the screen forward.
      • Remove the plug on the back of the screen that connects it to the camera.
      Ask FixBot
    6. Motorola V710 LCD screen replacement: step 6, image 1 of 2 Motorola V710 LCD screen replacement: step 6, image 2 of 2
      • Use the spudger to remove the screen.
      Ask FixBot
Michael Onnen
11 Reputation
1 Guide authored
Cal Poly, Team 8-49, Regan Winter 2010 Member of Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 40
All Time: 2,470
