Up to 20% off select tools
Motorola V710 Keyboard Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
15
All Time:
2,361
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help show you how to replace the keypad.
    1. Motorola V710 Keyboard Replacement, Battery: step 1, image 1 of 3 Motorola V710 Keyboard Replacement, Battery: step 1, image 2 of 3 Motorola V710 Keyboard Replacement, Battery: step 1, image 3 of 3
      • Press down on the back button while pulling away from the body of the phone to release the back cover.
      Ask FixBot
    2. Motorola V710 Keyboard Replacement: step 2, image 1 of 3 Motorola V710 Keyboard Replacement: step 2, image 2 of 3 Motorola V710 Keyboard Replacement: step 2, image 3 of 3
      • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
      Ask FixBot
    1. Motorola V710 Keyboard Replacement, Keypad: step 3, image 1 of 1
      • Unscrew the antenna with a clockwise motion and pull to remove the antenna.
      Ask FixBot
    2. Motorola V710 Keyboard Replacement: step 4, image 1 of 2 Motorola V710 Keyboard Replacement: step 4, image 2 of 2
      • Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver.
      Ask FixBot
    3. Motorola V710 Keyboard Replacement: step 5, image 1 of 2 Motorola V710 Keyboard Replacement: step 5, image 2 of 2
      • Use the spudger to remove the bottom plate.
      Ask FixBot
    4. Motorola V710 Keyboard Replacement: step 6, image 1 of 2 Motorola V710 Keyboard Replacement: step 6, image 2 of 2
      • Unscrew the bottom two screws with the T6 screwdriver.
      Ask FixBot
    5. Motorola V710 Keyboard Replacement: step 7, image 1 of 2 Motorola V710 Keyboard Replacement: step 7, image 2 of 2
      • Use the spudger to remove the keyboard plate.
      Ask FixBot
    6. Motorola V710 Keyboard Replacement: step 8, image 1 of 1
      • Use your fingers to push out the keyboard.
      Ask FixBot
Finish Line
Author
with
Karl Sanders
8 Reputation
7 Guides authored
Cal Poly, Team 8-49, Regan Winter 2010 Member of Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,361
