Motorola V60s Motherboard Replacement
  1. Motorola V60s Motherboard Replacement, Battery: step 1, image 1 of 3 Motorola V60s Motherboard Replacement, Battery: step 1, image 2 of 3 Motorola V60s Motherboard Replacement, Battery: step 1, image 3 of 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
    Ask FixBot
  2. Motorola V60s Motherboard Replacement: step 2, image 1 of 2 Motorola V60s Motherboard Replacement: step 2, image 2 of 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
    Ask FixBot
  3. Motorola V60s Motherboard Replacement, Motherboard: step 3, image 1 of 2 Motorola V60s Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
    Ask FixBot
  4. Motorola V60s Motherboard Replacement: step 4, image 1 of 3 Motorola V60s Motherboard Replacement: step 4, image 2 of 3 Motorola V60s Motherboard Replacement: step 4, image 3 of 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
    Ask FixBot
  5. Motorola V60s Motherboard Replacement: step 5, image 1 of 3 Motorola V60s Motherboard Replacement: step 5, image 2 of 3 Motorola V60s Motherboard Replacement: step 5, image 3 of 3
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
    Ask FixBot
  6. Motorola V60s Motherboard Replacement: step 6, image 1 of 3 Motorola V60s Motherboard Replacement: step 6, image 2 of 3 Motorola V60s Motherboard Replacement: step 6, image 3 of 3
    • Gently remove orange ribbon cable by prying up with spudger.
    Ask FixBot
  7. Motorola V60s Motherboard Replacement: step 7, image 1 of 2 Motorola V60s Motherboard Replacement: step 7, image 2 of 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
    Ask FixBot
Eric Freeman
12 Reputation
7 Guides authored
Cal Poly, Team 8-48, Regan Winter 2010 Member of Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,199
