Motorola V60s Front Chassis Disassembly
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
4
Past 30 Days:
34
All Time:
2,774
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
This guide shows how to take apart the front casing. This allows access to the front LCD screen.
Tools
    1. Motorola V60s Front Chassis Disassembly, Chassis: step 1, image 1 of 1
      • Push in and hold small release latch.
      • Hold the latch through step 2.
      Ask FixBot
    2. Motorola V60s Front Chassis Disassembly: step 2, image 1 of 3 Motorola V60s Front Chassis Disassembly: step 2, image 2 of 3 Motorola V60s Front Chassis Disassembly: step 2, image 3 of 3
      • While holding the release latch, use an opening tool to help you slide off the front cover.
      Ask FixBot
    3. Motorola V60s Front Chassis Disassembly: step 3, image 1 of 2 Motorola V60s Front Chassis Disassembly: step 3, image 2 of 2
      • Remove the two screws at top of phone with a Phillips #1 screwdriver.
      Ask FixBot
    4. Motorola V60s Front Chassis Disassembly: step 4, image 1 of 3 Motorola V60s Front Chassis Disassembly: step 4, image 2 of 3 Motorola V60s Front Chassis Disassembly: step 4, image 3 of 3
      • Use an opening tool to gently pry off the black cover, revealing the internal LCD display.
      Ask FixBot
Eric Freeman
12 Reputation
7 Guides authored
Cal Poly, Team 8-48, Regan Winter 2010 Member of Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 34
All Time: 2,774
