Up to 20% off select tools
Motorola V60i Keypad Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
89
All Time:
2,525
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Step-by-step guide to replacing your phone's keypad buttons.
    1. Motorola V60i Keypad Replacement, Battery: step 1, image 1 of 2 Motorola V60i Keypad Replacement, Battery: step 1, image 2 of 2
      • Flip the phone over so the back cover is facing up.
      • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
      Ask FixBot
    2. Motorola V60i Keypad Replacement: step 2, image 1 of 2 Motorola V60i Keypad Replacement: step 2, image 2 of 2
      • Pry up the back plate from the phone.
      • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
      Ask FixBot
    1. Motorola V60i Keypad Replacement, Back Plate: step 3, image 1 of 1
      • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
      Ask FixBot
    2. Motorola V60i Keypad Replacement: step 4, image 1 of 2 Motorola V60i Keypad Replacement: step 4, image 2 of 2
      • Simultaneously press the highlighted buttons on both sides of phone.
      Ask FixBot
    3. Motorola V60i Keypad Replacement: step 5, image 1 of 1
      • Separate the back plate from the rest of phone.
      • Do not pull the wire connecting the front and back plates.
      Ask FixBot
    1. Motorola V60i Keypad Replacement, Motherboard: step 6, image 1 of 1
      • Gently lift logic board from back plate.
      Ask FixBot
    2. Motorola V60i Keypad Replacement: step 7, image 1 of 2 Motorola V60i Keypad Replacement: step 7, image 2 of 2
      • Place logic board on front cover.
      • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
      Ask FixBot
    1. Motorola V60i Keypad Replacement, Keypad Sensor: step 8, image 1 of 2 Motorola V60i Keypad Replacement, Keypad Sensor: step 8, image 2 of 2
      • Once logic board is removed lift the green keypad sensor for the front plate.
      Ask FixBot
    1. Motorola V60i Keypad Replacement, Keypad: step 9, image 1 of 2 Motorola V60i Keypad Replacement, Keypad: step 9, image 2 of 2
      • To replace keypad buttons, lift off white tray containing buttons.
      Ask FixBot
Author
with
Elizabeth OBrien
52 Reputation
7 Guides authored
Cal Poly, Team 30-40, Garner Spring 2010 Member of Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 89
All Time: 2,525
