Up to 20% off select tools
Motorola V60c Side Buttons Replacement
Views: 5.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
23
All Time:
5,613
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
How to replace the side buttons.
    1. Motorola V60c Side Buttons Replacement, Battery: step 1, image 1 of 2 Motorola V60c Side Buttons Replacement, Battery: step 1, image 2 of 2
      • Depress the silver button.
      • Pull from top of phone to lift the cover.
      Ask FixBot
    2. Motorola V60c Side Buttons Replacement: step 2, image 1 of 2 Motorola V60c Side Buttons Replacement: step 2, image 2 of 2
      • Hold battery from both sides at the bottom.
      • Push upwards and gently lift to remove.
      Ask FixBot
    1. Motorola V60c Side Buttons Replacement, Side Buttons: step 3, image 1 of 1
      • Remove 4 screws from corners using T-6 screwdriver.
      • NOTE: Bottom two screws are gold.
      • NOTE: Make sure screws return to correct place when reassembling.
      Ask FixBot
    2. Motorola V60c Side Buttons Replacement: step 4, image 1 of 2 Motorola V60c Side Buttons Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to pry up back cover from two side clips.
      • NOTE: sticker might be attached to rest of phone.
      Ask FixBot
    3. Motorola V60c Side Buttons Replacement: step 5, image 1 of 1
      • Remove the back cover.
      Ask FixBot
    4. Motorola V60c Side Buttons Replacement: step 6, image 1 of 2 Motorola V60c Side Buttons Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to gently remove the orange ribbon cable.
      • Lift up the main logic board.
      • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
      Ask FixBot
    5. Motorola V60c Side Buttons Replacement: step 7, image 1 of 2 Motorola V60c Side Buttons Replacement: step 7, image 2 of 2
      • Carefully flip over main logic board.
      • Remove rubber side buttons.
      Ask FixBot
Author
with
Ryan Kuroiwa
1 Reputation
5 Guides authored
Cal Poly, Team 25-86, Amido Spring 2010 Member of Cal Poly, Team 25-86, Amido Spring 2010
CPSU-AMIDO-S10S25G86
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 5,613
