Up to 20% off select tools
Motorola V557 Screen Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
4
Past 30 Days:
20
All Time:
3,273
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
The screen is a common breaking point for cellular phones, and can be replaced to repair an unusable phone.
    1. Motorola V557 Screen Replacement, Faceplate: step 1, image 1 of 3 Motorola V557 Screen Replacement, Faceplate: step 1, image 2 of 3 Motorola V557 Screen Replacement, Faceplate: step 1, image 3 of 3
      • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
      Ask FixBot
    2. Motorola V557 Screen Replacement: step 2, image 1 of 2 Motorola V557 Screen Replacement: step 2, image 2 of 2
      • Remove the four 3.8 mm T-6 Torx screws.
      Ask FixBot
    3. Motorola V557 Screen Replacement: step 3, image 1 of 2 Motorola V557 Screen Replacement: step 3, image 2 of 2
      • Separate the cover from the edges using a plastic opening tool.
      Ask FixBot
    4. Motorola V557 Screen Replacement: step 4, image 1 of 2 Motorola V557 Screen Replacement: step 4, image 2 of 2
      • With the edges separated, close the phone and lift off the faceplate with your fingers.
      Ask FixBot
    1. Motorola V557 Screen Replacement, Camera: step 5, image 1 of 1
      • Gently peel off the plastic film from the metal plate above the camera lens as shown.
      Ask FixBot
    2. Motorola V557 Screen Replacement: step 6, image 1 of 2 Motorola V557 Screen Replacement: step 6, image 2 of 2
      • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
      • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
      Ask FixBot
    3. Motorola V557 Screen Replacement: step 7, image 1 of 2 Motorola V557 Screen Replacement: step 7, image 2 of 2
      • Lift and peel back the tape attaching metal casing to body of the phone.
      • Gently lift the metal cover and remove to expose the circuit board.
      Ask FixBot
    4. Motorola V557 Screen Replacement: step 8, image 1 of 2 Motorola V557 Screen Replacement: step 8, image 2 of 2
      • Using a plastic opening tool, pry or lift open the pink door shown.
      • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
      • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
      Ask FixBot
    5. Motorola V557 Screen Replacement: step 9, image 1 of 3 Motorola V557 Screen Replacement: step 9, image 2 of 3 Motorola V557 Screen Replacement: step 9, image 3 of 3
      • Use a plastic opening tool to dislodge and remove the rubber camera cover.
      Ask FixBot
    6. Motorola V557 Screen Replacement: step 10, image 1 of 2 Motorola V557 Screen Replacement: step 10, image 2 of 2
      • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
      Ask FixBot
    1. Motorola V557 Screen Replacement, Screen: step 11, image 1 of 3 Motorola V557 Screen Replacement, Screen: step 11, image 2 of 3 Motorola V557 Screen Replacement, Screen: step 11, image 3 of 3
      • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
      • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
      Ask FixBot
Author
with
Blair Frandeen
19 Reputation
4 Guides authored
Cal Poly, Team 7-50, Amido Fall 2010 Member of Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 20
All Time: 3,273
