Up to 20% off select tools
Motorola V557 Camera Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
94
All Time:
2,337
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you find that your Motorola V557 camera is not working properly, this guide will walk you through the steps to replace it. We will be replacing the entire camera along with the ribbon connecting it to the phone. A nonfunctioning camera may not show any picture on the screen or show a poor or unclear image. This would indicate that the camera needs to be repaired. This guide requires that the battery be below 25% for the safety of the repairer. No complicated skills or tools are needed for this repair. In order to complete this repair, tactile ability and hand tools are required. If this repair is done correctly your camera function should be restored and clear images will show up on the screen.
    1. Motorola V557 Camera Replacement, Battery: step 1, image 1 of 3 Motorola V557 Camera Replacement, Battery: step 1, image 2 of 3 Motorola V557 Camera Replacement, Battery: step 1, image 3 of 3
      • First, on the back of the phone find the silver button on the top left corner of the phone.
      • Simultaneously push down the button and slide the back plate down to reveal the battery.
      Ask FixBot
    2. Motorola V557 Camera Replacement: step 2, image 1 of 2 Motorola V557 Camera Replacement: step 2, image 2 of 2
      • Grab the lower edge of the battery at the two bottom corners.
      • Pull upward on the edges to remove the battery.
      Ask FixBot
    1. Motorola V557 Camera Replacement, Faceplate: step 3, image 1 of 3 Motorola V557 Camera Replacement, Faceplate: step 3, image 2 of 3 Motorola V557 Camera Replacement, Faceplate: step 3, image 3 of 3
      • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
      Ask FixBot
    2. Motorola V557 Camera Replacement: step 4, image 1 of 2 Motorola V557 Camera Replacement: step 4, image 2 of 2
      • Remove the four 3.8 mm T-6 Torx screws.
      Ask FixBot
    3. Motorola V557 Camera Replacement: step 5, image 1 of 2 Motorola V557 Camera Replacement: step 5, image 2 of 2
      • Separate the cover from the edges using a plastic opening tool.
      Ask FixBot
    4. Motorola V557 Camera Replacement: step 6, image 1 of 2 Motorola V557 Camera Replacement: step 6, image 2 of 2
      • With the edges separated, close the phone and lift off the faceplate with your fingers.
      Ask FixBot
    1. Motorola V557 Camera Replacement, Camera: step 7, image 1 of 1
      • Gently peel off the plastic film from the metal plate above the camera lens as shown.
      Ask FixBot
    2. Motorola V557 Camera Replacement: step 8, image 1 of 2 Motorola V557 Camera Replacement: step 8, image 2 of 2
      • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
      • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
      Ask FixBot
    3. Motorola V557 Camera Replacement: step 9, image 1 of 2 Motorola V557 Camera Replacement: step 9, image 2 of 2
      • Lift and peel back the tape attaching metal casing to body of the phone.
      • Gently lift the metal cover and remove to expose the circuit board.
      Ask FixBot
    4. Motorola V557 Camera Replacement: step 10, image 1 of 2 Motorola V557 Camera Replacement: step 10, image 2 of 2
      • Using a plastic opening tool, pry or lift open the pink door shown.
      • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
      • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
      Ask FixBot
    5. Motorola V557 Camera Replacement: step 11, image 1 of 3 Motorola V557 Camera Replacement: step 11, image 2 of 3 Motorola V557 Camera Replacement: step 11, image 3 of 3
      • Use a plastic opening tool to dislodge and remove the rubber camera cover.
      Ask FixBot
    6. Motorola V557 Camera Replacement: step 12, image 1 of 2 Motorola V557 Camera Replacement: step 12, image 2 of 2
      • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
      Ask FixBot
2 other people completed this guide.
Author
with
Matthew Sanders
43 Reputation
2 Guides authored
Cal Poly, Team 7-50, Amido Fall 2010 Member of Cal Poly, Team 7-50, Amido Fall 2010
CPSU-AMIDO-F10S7G50
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 94
All Time: 2,337
