Up to 20% off select tools
Motorola V551 Keypad Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
82
All Time:
2,774
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a guide showing how to replace and repair the keypad of the phone.
    1. Motorola V551 Keypad Replacement, Battery: step 1, image 1 of 2 Motorola V551 Keypad Replacement, Battery: step 1, image 2 of 2
      • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
      Ask FixBot
    2. Motorola V551 Keypad Replacement: step 2, image 1 of 1
      • Lever the battery out by pressing upwards on the bottom corners of the battery.
      Ask FixBot
    1. Motorola V551 Keypad Replacement, Circuit Board: step 3, image 1 of 3 Motorola V551 Keypad Replacement, Circuit Board: step 3, image 2 of 3 Motorola V551 Keypad Replacement, Circuit Board: step 3, image 3 of 3
      • Remove the rubber screw covers using a plastic spudger.
      • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
      Ask FixBot
    2. Motorola V551 Keypad Replacement: step 4, image 1 of 1
      • Unscrew the antenna.
      Ask FixBot
    3. Motorola V551 Keypad Replacement: step 5, image 1 of 3 Motorola V551 Keypad Replacement: step 5, image 2 of 3 Motorola V551 Keypad Replacement: step 5, image 3 of 3
      • Gently release the two latches using an opening tool.
      • The plastic latches are very fragile. Don’t use excessive force or they might break.
      • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
      • Lift the back panel off of the phone.
      Ask FixBot
    4. Motorola V551 Keypad Replacement: step 6, image 1 of 2 Motorola V551 Keypad Replacement: step 6, image 2 of 2
      • Loosen the copper circuit board connection with an opening tool.
      • Gently lift the copper connection.
      Ask FixBot
    5. Motorola V551 Keypad Replacement: step 7, image 1 of 3 Motorola V551 Keypad Replacement: step 7, image 2 of 3 Motorola V551 Keypad Replacement: step 7, image 3 of 3
      • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
      • Gently lift the motherboard off of the front panel.
      Ask FixBot
    1. Motorola V551 Keypad Replacement, Keypad: step 8, image 1 of 3 Motorola V551 Keypad Replacement, Keypad: step 8, image 2 of 3 Motorola V551 Keypad Replacement, Keypad: step 8, image 3 of 3
      • Push both side keys in so they are not sticking out of the phone.
      • Remove the keypad.
      Ask FixBot
2 other people completed this guide.
Author
with
gregatron
105 Reputation
6 Guides authored
Cal Poly, Team 6-6, Maness Fall 2009 Member of Cal Poly, Team 6-6, Maness Fall 2009
CPSU-MANESS-F09S6G6
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 82
All Time: 2,774
