Motorola V325 External Casing Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
30
All Time:
2,435
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The outer housing can be removed to be cleaned or swapped to a custom housing.
Tools
    1. Motorola V325 External Casing Replacement, External Casing: step 1, image 1 of 3 Motorola V325 External Casing Replacement, External Casing: step 1, image 2 of 3 Motorola V325 External Casing Replacement, External Casing: step 1, image 3 of 3
      • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
      • Lift the panel off of the phone.
      Ask FixBot
    2. Motorola V325 External Casing Replacement: step 2, image 1 of 3 Motorola V325 External Casing Replacement: step 2, image 2 of 3 Motorola V325 External Casing Replacement: step 2, image 3 of 3
      • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
      Ask FixBot
    3. Motorola V325 External Casing Replacement: step 3, image 1 of 2 Motorola V325 External Casing Replacement: step 3, image 2 of 2
      • Unscrew the four screws using the T6 Torx Screwdriver.
      Ask FixBot
    4. Motorola V325 External Casing Replacement: step 4, image 1 of 3 Motorola V325 External Casing Replacement: step 4, image 2 of 3 Motorola V325 External Casing Replacement: step 4, image 3 of 3
      • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
      Ask FixBot
Minh Tran
2 Reputation
2 Guides authored
Cal Poly, Team 4-15, Forte Winter 2010 Member of Cal Poly, Team 4-15, Forte Winter 2010
CPSU-FORTE-W10S4G15
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 2,435
