Motorola V276 Speaker Replacement
  1. Motorola V276 Speaker Replacement, Battery: step 1, image 1 of 1
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    Ask FixBot
  2. Motorola V276 Speaker Replacement: step 2, image 1 of 1
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    Ask FixBot
  3. Motorola V276 Speaker Replacement: step 3, image 1 of 2 Motorola V276 Speaker Replacement: step 3, image 2 of 2
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    Ask FixBot
  4. Motorola V276 Speaker Replacement, Speaker: step 4, image 1 of 1
    • Use Spudger to remove rubber plug from upper left corner of the back of the phone
    Ask FixBot
  5. Motorola V276 Speaker Replacement: step 5, image 1 of 1
    • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
    Ask FixBot
  6. Motorola V276 Speaker Replacement: step 6, image 1 of 3 Motorola V276 Speaker Replacement: step 6, image 2 of 3 Motorola V276 Speaker Replacement: step 6, image 3 of 3
    • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
    Ask FixBot
  7. Motorola V276 Speaker Replacement: step 7, image 1 of 2 Motorola V276 Speaker Replacement: step 7, image 2 of 2
    • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
    Ask FixBot
  8. Motorola V276 Speaker Replacement: step 8, image 1 of 2 Motorola V276 Speaker Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
    Ask FixBot
  9. Motorola V276 Speaker Replacement: step 9, image 1 of 1
    • Using a spudger, remove the speaker
    Ask FixBot
Kyle Klitzner
1 Reputation
2 Guides authored
Cal Poly, Team 27-96, Amido Spring 2010 Member of Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Members
26 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 1,309
