Motorola V276 Motherboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
32
All Time:
1,507
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the Motorola V276 Motherboard.
Tools
    1. Motorola V276 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Locate the silver button on the back of the phone, near the bottom.
      • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
      • The back cover should slide off easily.
      Ask FixBot
    2. Motorola V276 Motherboard Replacement: step 2, image 1 of 1
      • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
      • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
      • Now that the battery is exposed, use your fingers to remove the it from the phone.
      Ask FixBot
    3. Motorola V276 Motherboard Replacement: step 3, image 1 of 2 Motorola V276 Motherboard Replacement: step 3, image 2 of 2
      • Note the metal connections on the phone, which are now exposed with the battery removed.
      • There are corresponding metal connectors on the replacement battery.
      • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
      Ask FixBot
    1. Motorola V276 Motherboard Replacement, Motherboard: step 4, image 1 of 1
      • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
      Ask FixBot
    2. Motorola V276 Motherboard Replacement: step 5, image 1 of 1
      • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
      Ask FixBot
    3. Motorola V276 Motherboard Replacement: step 6, image 1 of 3 Motorola V276 Motherboard Replacement: step 6, image 2 of 3 Motorola V276 Motherboard Replacement: step 6, image 3 of 3
      • Three tabs will hold the back plastic plate in.
      • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
      • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
      Ask FixBot
    4. Motorola V276 Motherboard Replacement: step 7, image 1 of 3 Motorola V276 Motherboard Replacement: step 7, image 2 of 3 Motorola V276 Motherboard Replacement: step 7, image 3 of 3
      • Use a spudger to remove the ribbon cable from the motherboard.
      • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
      Ask FixBot
    5. Motorola V276 Motherboard Replacement: step 8, image 1 of 1
      • Gently peel back the motherboard from the main part of the phone.
      Ask FixBot
Jonathan Cheung
1 Reputation
3 Guides authored
Cal Poly, Team 27-96, Amido Spring 2010 Member of Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 1,507
