Motorola V276 Battery Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
35
All Time:
2,136
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Replacing phone battery.
Parts
Tools
  • Spudger
    4.9
    1. Motorola V276 Battery Replacement, Battery: step 1, image 1 of 1
      • Locate the silver button on the back of the phone, near the bottom.
      • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
      • The back cover should slide off easily.
      Ask FixBot
    2. Motorola V276 Battery Replacement: step 2, image 1 of 1
      • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
      • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
      • Now that the battery is exposed, use your fingers to remove the it from the phone.
      Ask FixBot
    3. Motorola V276 Battery Replacement: step 3, image 1 of 2 Motorola V276 Battery Replacement: step 3, image 2 of 2
      • Note the metal connections on the phone, which are now exposed with the battery removed.
      • There are corresponding metal connectors on the replacement battery.
      • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
      Ask FixBot
Jason Kilroy
1 Reputation
3 Guides authored
Cal Poly, Team 27-96, Amido Spring 2010 Member of Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 35
All Time: 2,136
