Motorola V190 Mini-USB Port/Motherboard Replacement
  1. Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: step 1, image 1 of 2 Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: step 1, image 2 of 2
    • Rotate the antenna counter-clockwise until the antenna is completely removed.
    Ask FixBot
  2. Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: step 2, image 1 of 2 Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: step 2, image 2 of 2
    • Press the button at the bottom of the back cover.
    • Pull the back cover down.
    • Remove the battery.
    • Our device is missing the battery.
    Ask FixBot
  3. Motorola V190 Mini-USB Port/Motherboard Replacement, Mini-USB Port/Motherboard: step 3, image 1 of 1
    • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
    Ask FixBot
  4. Motorola V190 Mini-USB Port/Motherboard Replacement: step 4, image 1 of 3 Motorola V190 Mini-USB Port/Motherboard Replacement: step 4, image 2 of 3 Motorola V190 Mini-USB Port/Motherboard Replacement: step 4, image 3 of 3
    • Use the iFixit opening tool to pry open the crevice at the top of phone.
    • Use the same tool to pry open the crevice at the bottom of the phone.
    • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
    Ask FixBot
  5. Motorola V190 Mini-USB Port/Motherboard Replacement: step 5, image 1 of 3 Motorola V190 Mini-USB Port/Motherboard Replacement: step 5, image 2 of 3 Motorola V190 Mini-USB Port/Motherboard Replacement: step 5, image 3 of 3
    • Remove the black rubber piece from the top of the motherboard.
    • Disconnect the rectangular ribbon from the motherboard.
    • Remove the motherboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 35
All Time: 339
