Up to 20% off select tools
Motorola V190 Keypad Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
65
All Time:
752
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If the keypad of your Motorola V190 cellular phone is not responding correctly, if the buttons stick, or if your keypad is missing a button, follow this guide to replace the keypad. The keypad uses the motherboard, allowing you to send and receive calls, navigate the phone, and send text messages.
Check for any dirt on the keypad or motherboard while the keypad is removed. Use a compressed air canister to remove any dirt.
Make sure to power down your phone before beginning.
    1. Motorola V190 Keypad Replacement, Antenna: step 1, image 1 of 2 Motorola V190 Keypad Replacement, Antenna: step 1, image 2 of 2
      • Rotate the antenna counter-clockwise until the antenna is completely removed.
      Ask FixBot
    1. Motorola V190 Keypad Replacement, Battery: step 2, image 1 of 2 Motorola V190 Keypad Replacement, Battery: step 2, image 2 of 2
      • Press the button at the bottom of the back cover.
      • Pull the back cover down.
      • Remove the battery.
      • Our device is missing the battery.
      Ask FixBot
    1. Motorola V190 Keypad Replacement, Mini-USB Port/Motherboard: step 3, image 1 of 1
      • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
      Ask FixBot
    2. Motorola V190 Keypad Replacement: step 4, image 1 of 3 Motorola V190 Keypad Replacement: step 4, image 2 of 3 Motorola V190 Keypad Replacement: step 4, image 3 of 3
      • Use the iFixit opening tool to pry open the crevice at the top of phone.
      • Use the same tool to pry open the crevice at the bottom of the phone.
      • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
      Ask FixBot
    3. Motorola V190 Keypad Replacement: step 5, image 1 of 3 Motorola V190 Keypad Replacement: step 5, image 2 of 3 Motorola V190 Keypad Replacement: step 5, image 3 of 3
      • Remove the black rubber piece from the top of the motherboard.
      • Disconnect the rectangular ribbon from the motherboard.
      • Remove the motherboard.
      Ask FixBot
    1. Motorola V190 Keypad Replacement, Keypad: step 6, image 1 of 3 Motorola V190 Keypad Replacement, Keypad: step 6, image 2 of 3 Motorola V190 Keypad Replacement, Keypad: step 6, image 3 of 3
      • Reopen the phone.
      • Press the push buttons (the volume buttons) through the phone frame to fully remove the keypad.
      • Push the keypad through the keypad frame.
      • Remove the keypad by lifting it over the screw holes.
      Ask FixBot
Author
with
Michael Pollock
545 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 65
All Time: 752
