Motorola V180 Motherboard Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
39
All Time:
2,410
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
The following instructions will guide you through the repair of your Motorola V180 Motherboard. The Motorola V180 Motherboard should be replaced when it becomes unresponsive or overheats. Replacing the motherboard should allow the Motorola to function like usual. This task does not require any special skills however, be careful as some parts do easily fall off.
Tools
  • Spudger
    4.9
    1. Motorola V180 Motherboard Replacement, Battery: step 1, image 1 of 3 Motorola V180 Motherboard Replacement, Battery: step 1, image 2 of 3 Motorola V180 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Completely power off the Motorola V180.
      • Flip the phone over to its back side.
      • Press down the button and slide off the back cover.
      • Remove the old battery.
      Ask FixBot
    1. Motorola V180 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Motorola V180 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Motorola V180 Motherboard Replacement, Motherboard: step 2, image 3 of 3
      • Power off the Motorola V180.
      • Hold down the button and slide off the back cover.
      • Remove the battery.
      Ask FixBot
    2. Motorola V180 Motherboard Replacement: step 3, image 1 of 3 Motorola V180 Motherboard Replacement: step 3, image 2 of 3 Motorola V180 Motherboard Replacement: step 3, image 3 of 3
      • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
      • Remove the SIM card located on the back of the phone.
      • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
      Ask FixBot
    3. Motorola V180 Motherboard Replacement: step 4, image 1 of 2 Motorola V180 Motherboard Replacement: step 4, image 2 of 2
      • Unclip the pronged rectangle connector ribbon attached to the motherboard.
      • Remove the motherboard.
      Ask FixBot
Tyler Knisley
1 Reputation
6 Guides authored
Cal Poly, Team 6-16, Maness Spring 2010 Member of Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 39
All Time: 2,410
