Motorola V180 Motherboard Replacement
    1. Motorola V180 Motherboard Replacement, Battery: step 1, image 1 of 3 Motorola V180 Motherboard Replacement, Battery: step 1, image 2 of 3 Motorola V180 Motherboard Replacement, Battery: step 1, image 3 of 3
      • Completely power off the Motorola V180.
      • Flip the phone over to its back side.
      • Press down the button and slide off the back cover.
      • Remove the old battery.
      Ask FixBot
    1. Motorola V180 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Motorola V180 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Motorola V180 Motherboard Replacement, Motherboard: step 2, image 3 of 3
      • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
      • Remove the SIM card located on the back of the phone.
      • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
      Ask FixBot
    2. Motorola V180 Motherboard Replacement: step 3, image 1 of 2 Motorola V180 Motherboard Replacement: step 3, image 2 of 2
      • Unclip the pronged rectangle connector ribbon attached to the motherboard.
      • Remove the motherboard by lifting it up out of the keypad.
      Ask FixBot
Tyler Knisley
1 Reputation
6 Guides authored
Cal Poly, Team 6-16, Maness Spring 2010 Member of Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,917
