Motorola V180 Connector Ribbon Replacement
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: step 1, image 1 of 1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
    Ask FixBot
  2. Motorola V180 Connector Ribbon Replacement: step 2, image 1 of 1
    • Remove the four screws securing the front cover.
    Ask FixBot
  3. Motorola V180 Connector Ribbon Replacement: step 3, image 1 of 1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
    Ask FixBot
  4. Motorola V180 Connector Ribbon Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
    Ask FixBot
  5. Motorola V180 Connector Ribbon Replacement: step 5, image 1 of 1
    • The black rubber component can now easily be taken off.
    Ask FixBot
  6. Motorola V180 Connector Ribbon Replacement: step 6, image 1 of 1
    • Use a soldering iron to detach the connector ribbon from the phone.
    Ask FixBot
Tyler Knisley
1 Reputation
7 Guides authored
Cal Poly, Team 6-16, Maness Spring 2010 Member of Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 2,909
