Up to 20% off select tools
Motorola Triumph Camera Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
30
All Time:
618
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
  • T4 Torx Screwdriver
    4.8
  • T5 Torx Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide details the process of removing the camera from an Motorola Triumph. Installation of the camera can be accomplished by reversing the process.
    1. Motorola Triumph Camera Replacement, Battery: step 1, image 1 of 3 Motorola Triumph Camera Replacement, Battery: step 1, image 2 of 3 Motorola Triumph Camera Replacement, Battery: step 1, image 3 of 3
      • Slide the back cover down.
      • Lift the back cover up.
      • Pry the battery out with the spudger
      Ask FixBot
    2. Motorola Triumph Camera Replacement: step 2, image 1 of 1
      • Gently pry out the battery using the spudger
      Ask FixBot
    1. Motorola Triumph Camera Replacement, Speakers: step 3, image 1 of 1
      • After removing the Battery remove the two screws with a T4 screwdriver.
      Ask FixBot
    2. Motorola Triumph Camera Replacement: step 4, image 1 of 1
      • With the spudger, go around the seam of the phone and pry away the back chassis.
      Ask FixBot
    3. Motorola Triumph Camera Replacement: step 5, image 1 of 1
      • Using the T5 screwdriver, remove all the four screws shown in the picture.
      Ask FixBot
    4. Motorola Triumph Camera Replacement: step 6, image 1 of 1
      • Lift up the motherboard out of the device,
      Ask FixBot
    5. Motorola Triumph Camera Replacement: step 7, image 1 of 1
      • Pry the speakers out using the plastic spudger.
      Ask FixBot
    1. Motorola Triumph Camera Replacement, Camera: step 8, image 1 of 1
      • Locate the camera at the top of the motherboard.
      Ask FixBot
    2. Motorola Triumph Camera Replacement: step 9, image 1 of 2 Motorola Triumph Camera Replacement: step 9, image 2 of 2
      • Use the the spudger to unclip the connector above the camera.
      • Remove the camera.
      Ask FixBot
Author
with
greg
12 Reputation
5 Guides authored
USF Tampa, Team 7-5, Leahy Fall 2014 Member of USF Tampa, Team 7-5, Leahy Fall 2014
USFT-LEAHY-F14S7G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 618
