Up to 20% off select tools
Motorola Rival Keyboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
87
All Time:
783
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If your Motorola Rival’s keyboard is unresponsive or certain keys stop working, replacing it can restore its functionality. A working keyboard is essential for texting, dialing, and navigating your phone.
This repair is rated as moderate. While it doesn’t require advanced technical skills, it does call for attention to detail and patience. The process involves removing various screws, buttons, and panels to access the keyboard, which is secured beneath the motherboard.
Before you begin, ensure the phone is powered off and disconnected from any external power sources. Be sure to have the necessary tools, including the iFixit Opening Tool and the Phillips #00 screwdriver from the 64 Bit Driver Kit, ready to go.
    1. Motorola Rival Keyboard Replacement, Keyboard: step 1, image 1 of 3 Motorola Rival Keyboard Replacement, Keyboard: step 1, image 2 of 3 Motorola Rival Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Push down on the release tab and pull the back cover away from the device, exposing the battery.
      Ask FixBot
    2. Motorola Rival Keyboard Replacement: step 2, image 1 of 2 Motorola Rival Keyboard Replacement: step 2, image 2 of 2
      • Lift the battery from its compartment to remove it.
      Ask FixBot
    3. Motorola Rival Keyboard Replacement: step 3, image 1 of 2 Motorola Rival Keyboard Replacement: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the six screws around the edge of the device.
      Ask FixBot
    4. Motorola Rival Keyboard Replacement: step 4, image 1 of 2 Motorola Rival Keyboard Replacement: step 4, image 2 of 2
      • Insert the iFixit Opening Tool into the seam where the front and back panels meet and work your way around the perimeter to separate the two panels.
      • Once the two panels are separated, set the front panel to the side. You will be working with the back panel to access the keyboard.
      • The motherboard is now exposed on the back panel.
      Ask FixBot
    5. Motorola Rival Keyboard Replacement: step 5, image 1 of 1
      • Use the iFixit Opening Tool to lift the camera button and remove it from its position.
      Ask FixBot
    6. Motorola Rival Keyboard Replacement: step 6, image 1 of 1
      • Use the iFixit Opening Tool to lift the lock/mute button and remove it from its position.
      Ask FixBot
    7. Motorola Rival Keyboard Replacement: step 7, image 1 of 1
      • Use the iFixit Opening Tool to lift the volume buttons and remove them from their position.
      Ask FixBot
    8. Motorola Rival Keyboard Replacement: step 8, image 1 of 2 Motorola Rival Keyboard Replacement: step 8, image 2 of 2
      • Slide the keyboard out.
      • Use a Phillips #00 screwdriver to remove all of the screws.
      Ask FixBot
    9. Motorola Rival Keyboard Replacement: step 9, image 1 of 3 Motorola Rival Keyboard Replacement: step 9, image 2 of 3 Motorola Rival Keyboard Replacement: step 9, image 3 of 3
      • Insert the iFixit Opening Tool under the edges of the motherboard to lift it out of the back panel and expose the keyboard.
      Ask FixBot
    10. Motorola Rival Keyboard Replacement: step 10, image 1 of 1
      • Remove the old keyboard from the frame.
      • Place the new keyboard into the frame and align the buttons into their respective openings.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
Author
with
Sekani Paul
231 Reputation
2 Guides authored
UMass Dartmouth, Team 1-8, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-8, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G8
2 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 87
All Time: 783
