Motorola Razr V3m Screen/Camera Replacement
  1. Motorola Razr V3m Screen/Camera Replacement, Battery: step 1, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement, Battery: step 1, image 2 of 2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
    Ask FixBot
  2. Motorola Razr V3m Screen/Camera Replacement: step 2, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement: step 2, image 2 of 2
    • Push the top edge of the battery and lift away from the phone.
    Ask FixBot
  3. Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: step 3, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: step 3, image 2 of 2
    • Remove the 4 screws on the corners of the inside screen with the T4 screwdriver
    • The phone may have rubber plugs covering the screws of the inside screen. If so, remove the rubber plugs with a thin metal needle.
    Ask FixBot
  4. Motorola Razr V3m Screen/Camera Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to pry the external shell off of the phone.
    • Use care when doing this step because you don’t want the external shell or the pieces inside the phone to break.
    Ask FixBot
  5. Motorola Razr V3m Screen/Camera Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the two side buttons with tweezers.
    Ask FixBot
  6. Motorola Razr V3m Screen/Camera Replacement: step 6, image 1 of 1
    • Use tweezers to remove the circular magnetic ring covering the camera.
    Ask FixBot
  7. Motorola Razr V3m Screen/Camera Replacement: step 7, image 1 of 2 Motorola Razr V3m Screen/Camera Replacement: step 7, image 2 of 2
    • Use a spudger to pry the screen from the inside front part of the phone.
    • You may choose to use tweezers to remove the screen instead.
    Ask FixBot
Daniel Simcock
752 Reputation
6 Guides authored
UMass Dartmouth, Team 3-2, Shastany Fall 2015 Member of UMass Dartmouth, Team 3-2, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G2
4 Members
16 Guides authored
1 Guide Comment
where can this part be purchased?
Alex Alexander - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 34
All Time: 729
