Motorola Razr V3c Lower Casing (CDMA) Replacement
  1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): step 1, image 1 of 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): step 1, image 2 of 3 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): step 1, image 3 of 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
    Ask FixBot
  2. Motorola Razr V3c Lower Casing (CDMA) Replacement: step 2, image 1 of 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: step 2, image 2 of 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
    Ask FixBot
  3. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): step 3, image 1 of 1
    • Unscrew the two screws in the back using the T6.
    Ask FixBot
  4. Motorola Razr V3c Lower Casing (CDMA) Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
    Ask FixBot
  5. Motorola Razr V3c Lower Casing (CDMA) Replacement: step 5, image 1 of 1
    • Peel off the connector between the motherboard and the body of the phone.
    Ask FixBot
  6. Motorola Razr V3c Lower Casing (CDMA) Replacement: step 6, image 1 of 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
    Ask FixBot
  7. Motorola Razr V3c Lower Casing (CDMA) Replacement: step 7, image 1 of 2 Motorola Razr V3c Lower Casing (CDMA) Replacement: step 7, image 2 of 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
    Ask FixBot
  8. Motorola Razr V3c Lower Casing (CDMA) Replacement: step 8, image 1 of 1
    • Pull out the speaker.
    Ask FixBot
  9. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): step 9, image 1 of 2 Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): step 9, image 2 of 2
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
    Ask FixBot
  10. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): step 10, image 1 of 1
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
    Ask FixBot
  11. Motorola Razr V3c Lower Casing (CDMA) Replacement: step 11, image 1 of 1
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
    Ask FixBot
krisko
104 Reputation
4 Guides authored
Cal Poly, Team 11-4, Forte Winter 2010 Member of Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 6,675
