Motorola Razr V3 Camera Replacement
Video Overview
    1. Motorola Razr V3 Camera Replacement, Battery: step 1, image 1 of 2 Motorola Razr V3 Camera Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover by pressing down the silver button.
      • Pull the cover away from the phone.
      Ask FixBot
    2. Motorola Razr V3 Camera Replacement: step 2, image 1 of 2 Motorola Razr V3 Camera Replacement: step 2, image 2 of 2
      • Remove the battery by pushing down on the top and pulling it away from the phone.
      Ask FixBot
    1. Motorola Razr V3 Camera Replacement, Upper Casing: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to pry off the four rubber screw covers from the inside face.
      • Our phone is missing the two left screw covers, be careful not to lose yours too!
      Ask FixBot
    2. Motorola Razr V3 Camera Replacement: step 4, image 1 of 1
      • Remove the four T5 Torx screws that were underneath the rubber covers.
      Ask FixBot
    3. Motorola Razr V3 Camera Replacement: step 5, image 1 of 1
      • Use the plastic opening tool to pry the top cover away from the phone.
      • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
      Ask FixBot
    1. Motorola Razr V3 Camera Replacement, Camera: step 6, image 1 of 2 Motorola Razr V3 Camera Replacement, Camera: step 6, image 2 of 2
      Buy
      • Use tweezers to flip up the ZIF tab on the camera ribbon cable socket.
      • Gently pull the camera ribbon cable out of the ZIF socket.
      Ask FixBot
    2. Motorola Razr V3 Camera Replacement: step 7, image 1 of 1
      • Using a pair of tweezers gently grab and remove the camera from the phone.
      Ask FixBot
2 other people completed this guide.
Christian
281 Reputation
2 Guides authored
Cal Poly, Team 3-46, Amido Spring 2013 Member of Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 35
All Time: 2,622
