Motorola RIZR Z3 Motherboard Replacement
  1. Motorola RIZR Z3 Motherboard Replacement, Battery: step 1, image 1 of 2 Motorola RIZR Z3 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
    Ask FixBot
  2. Motorola RIZR Z3 Motherboard Replacement: step 2, image 1 of 2 Motorola RIZR Z3 Motherboard Replacement: step 2, image 2 of 2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
    Ask FixBot
  3. Motorola RIZR Z3 Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
    Ask FixBot
  4. Motorola RIZR Z3 Motherboard Replacement: step 4, image 1 of 2 Motorola RIZR Z3 Motherboard Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
    Ask FixBot
  5. Motorola RIZR Z3 Motherboard Replacement: step 5, image 1 of 1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
    Ask FixBot
  6. Motorola RIZR Z3 Motherboard Replacement: step 6, image 1 of 2 Motorola RIZR Z3 Motherboard Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
    Ask FixBot
  7. Motorola RIZR Z3 Motherboard Replacement: step 7, image 1 of 2 Motorola RIZR Z3 Motherboard Replacement: step 7, image 2 of 2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
    Ask FixBot
  8. Motorola RIZR Z3 Motherboard Replacement: step 8, image 1 of 2 Motorola RIZR Z3 Motherboard Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
    Ask FixBot
Andrew Brock
8 Reputation
1 Guide authored
Cal Poly, Team 5-34, Amido Fall 2011 Member of Cal Poly, Team 5-34, Amido Fall 2011
CPSU-AMIDO-F11S5G34
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,645
