Motorola RAZR V3i Battery Replacement
Views: 9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
163
All Time:
8,963
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is a guide for replacing the battery of a Motorola RAZR V3i. With time, the battery life decreases and cannot work as efficiently as it did when first purchased. Replace your battery when your phone is no longer holding a charge, when it is dying rapidly after minimal change in use, and/or if the battery is swollen. Make sure the battery is completely discharged before attempting to do this replacement. Be careful to not puncture the battery, under any circumstances. If the battery is swollen, take extra precautions, as this is a sign of a damaged battery. Use protective equipment such as eye protection and gloves. Do not expose the battery to heat or moisture. Consider professional help if you have any issues.
    1. Motorola RAZR V3i Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
      • If you have a phone case, it has to be removed.
      Ask FixBot
    2. Motorola RAZR V3i Battery Replacement: step 2, image 1 of 3 Motorola RAZR V3i Battery Replacement: step 2, image 2 of 3 Motorola RAZR V3i Battery Replacement: step 2, image 3 of 3
      • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
      • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
      • The flat edge of a credit card or other flat object will also work.
      Ask FixBot
    3. Motorola RAZR V3i Battery Replacement: step 3, image 1 of 3 Motorola RAZR V3i Battery Replacement: step 3, image 2 of 3 Motorola RAZR V3i Battery Replacement: step 3, image 3 of 3
      • Remove the battery by pushing down on it from the top while gently pulling it outwards.
      • Be careful not to use too much force as the battery retaining tab could be damaged.
      Ask FixBot
Finish Line
5 other people completed this guide.
Nigel
133 Reputation
2 Guides authored
Cuesta, Team 1-5, Zipperian Fall 2011 Member of Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Member
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 163
All Time: 8,963
