Up to 20% off select tools
Motorola Q Global Camera Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
27
All Time:
1,098
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will focus on disassembling the necessary components for the phone in order to get to the camera hardware and remove it from the motherboard.
    1. Motorola Q Global Camera Replacement, Battery: step 1, image 1 of 2 Motorola Q Global Camera Replacement, Battery: step 1, image 2 of 2
      • Turn the phone face down.
      • Press and hold the release button in the middle of the back panel.
      • Slide the bottom panel down to remove.
      Ask FixBot
    2. Motorola Q Global Camera Replacement: step 2, image 1 of 2 Motorola Q Global Camera Replacement: step 2, image 2 of 2
      • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
      • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
      Ask FixBot
    1. Motorola Q Global Camera Replacement, Camera: step 3, image 1 of 1
      • Press inward on the upper casing.
      Ask FixBot
    2. Motorola Q Global Camera Replacement: step 4, image 1 of 1
      • Slide the upper case to the right and lift up.
      • Lift the camera sticker so that it doesn't get damaged.
      Ask FixBot
    3. Motorola Q Global Camera Replacement: step 5, image 1 of 2 Motorola Q Global Camera Replacement: step 5, image 2 of 2
      • Remove the six labeled screws with a T5 Torx Screwdriver.
      Ask FixBot
    4. Motorola Q Global Camera Replacement: step 6, image 1 of 1
      • Once the screws are removed, use the plastic opening tool to remove the black casing.
      Ask FixBot
    5. Motorola Q Global Camera Replacement: step 7, image 1 of 2 Motorola Q Global Camera Replacement: step 7, image 2 of 2
      • Remove both screws on the mounted surface with a T5 screwdriver.
      Ask FixBot
    6. Motorola Q Global Camera Replacement: step 8, image 1 of 2 Motorola Q Global Camera Replacement: step 8, image 2 of 2
      • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
      Ask FixBot
    7. Motorola Q Global Camera Replacement: step 9, image 1 of 1
      • Use the plastic opening tool to lift the camera from the phone.
      Ask FixBot
    8. Motorola Q Global Camera Replacement: step 10, image 1 of 1
      • The new camera can now be attached to the motherboard.
      Ask FixBot
Author
with
Jorge Vanegas Moran
8 Reputation
1 Guide authored
Cal Poly, Team 6-31, Regan Fall 2012 Member of Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 27
All Time: 1,098
