Motorola One Action Battery Replacement
    1. Motorola One Action Battery Replacement, Pry open back cover: step 1, image 1 of 1
      • Use the IFixit prying and opening tool to not damage the phone like I did.
      • The red line indicates the opening, follow it all the way around the phone.
      • Use a hair dryer or heat gun to soften the glue if necessary.
      Ask FixBot
    2. Motorola One Action Battery Replacement, Disconnect fingerprint sensor: step 2, image 1 of 1
      • Peel the small yellow tab away with a small flathead screwdriver.
      • Slide the metal shield down to unlock and remove it.
      Ask FixBot
    3. Motorola One Action Battery Replacement, Undo the screws: step 3, image 1 of 1
      • Undo all the screws on the top cover.
      Ask FixBot
    4. Motorola One Action Battery Replacement, Remove top cover: step 4, image 1 of 1
      • Use a small flathead to loosen the cover.
      • Around the red markers are little clips that keep it in place.
      Ask FixBot
    5. Motorola One Action Battery Replacement, Replace battery: step 5, image 1 of 1
      • Inside the red marker, disconnect the battery cable and carefully pull the battery out.
      • Use a non-metal prying tool to pull the corners up and apply heat to soften the glue in the process.
      • Be careful and make sure that the battery doesn't bend too far or breaks.
      Ask FixBot
9 other people completed this guide.
Ferre Vekemans
352 Reputation
1 Guide authored
1 Guide Comment
Man, is that battery sticky.... Anyway good writeup, works like a charm
dan - Reply Share
Past 24 Hours: 9
Past 7 Days: 36
Past 30 Days: 153
All Time: 10,638
