Motorola Nextel i880 Antenna Replacement
  1. Motorola Nextel i880 Antenna Replacement, Antenna: step 1, image 1 of 1
    • Remove back cover of the phone by disengaging the clip and lifting up on the cover.
    Ask FixBot
  2. Motorola Nextel i880 Antenna Replacement: step 2, image 1 of 1
    • Locate the screw on the top left portion of the phone; just below the antenna. Using a T4 Torx screwdriver remove the screw.
    Ask FixBot
  3. Motorola Nextel i880 Antenna Replacement: step 3, image 1 of 1
    • Slide antenna out of the phone.
    • Ensure that the protective plastic sleeve is not lost in removal.
    Ask FixBot
  4. Motorola Nextel i880 Antenna Replacement: step 4, image 1 of 1
    • Slide and secure new antenna into position. Make sure metal receiver is facing forward.
    Ask FixBot
  5. Motorola Nextel i880 Antenna Replacement: step 5, image 1 of 1
    • Reattach back cover and secure all components in place.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ryan
9 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 392
